StarTech.com 3 Port PCIe SATA III RAID Controller Card w/ mSATA Slot and HyperDuo SSD Tiering
Quicklinx: 9KMMWS00 Mfr#: PEXMSATA343
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Add 1 internal mSATA slot and 3 internal SATA III (6Gbps) ports to a computer through a PCI Express x2 slot. The PEXMSATA343 3-Port PCI Express 2.0 SATA Card with HyperDuo adds an internal mSATA SSD (Solid State Drive) slot plus three internal SATA III ports to your computer through a PCIe x2 slot, adding multiple 6 Gbps internal connections that enable you to improve the overall speed and storage capacity of your computer by connecting high-performance SSDs and hard drives.
Featuring HyperDuo technology, the SATA card offers SSD auto-tiering which lets you balance the performance advantages of SSD storage with the cost-effectiveness and large capacity of standard hard drives. By combining SSD and HDD drives into a single volume (up to 3 SSD + 1 HDD), HyperDuo discreetly works in the background to identify and move frequently accessed files to the faster SSD drive(s) for improved data throughput - up to 80% of SSD performance! (Note: The HyperDuo automatic storage tiering feature is compatible with computers that use a BIOS.)
The PCIe SATA controller card offers Port Multiplier (PM) support, so multiple SATA drives can be connected over a single cable, for a total of 7 drives (Up to 4 drives through PM on one port, and a single drive to the remaining 2 ports and mSATA slot). Plus, the SATA controller card offers an effective hardware RAID solution, with native RAID (0, 1) support.
You can install a SSD directly to the card via a convenient metal latching clip to help relieve the internal space constraints often associated with multiple hard drive configurations. Plus the controller card also includes a low profile/half-height installation bracket for small form factor (SFF) systems.
StarTech.com 3 Port PCI Express 2.0 SATA III 6 Gbps RAID Controller Card w/ mSATA Slot and HyperDuo SSD Tiering - storage controller (RAID) - SATA 6Gb/s - PCIe 2.0 x2
Storage controller (RAID) - plug-in card - low profile
Bus Type
PCIe 2.0 x2
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Disk array (RAID)
Channel Qty
4
RAID Level
RAID 0, RAID 1, RAID 10, JBOD
Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple MacOS X 10.6 - 10.9
2 cm x 11.5 cm x 12 cm
55 g
P/N: ST521PMINT
Host Bus
PCIe 2.0 x2
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Disk array (RAID)
Channel Qty
4
RAID Level
Marvell 88SE9230
3 x SATA 6Gb/s - SATA (internal) , 1 x SATA 6Gb/s - mSATA (internal)
Low-profile bracket
FCC, RoHS
Software Included
Drivers & Utilities
2 cm
11.5 cm
12 cm
55 g
5 °C
50 °C
20 - 80% (non-condensing)
P/N: ST521PMINT
9KMM StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
9KMM StarTech.com 12in Latching SATA Cable In Stock £6.16
9KMM StarTech.com 18in Latching SATA Cable In Stock £4.24
9KMM StarTech.com 8in Latching SATA to SATA Cable - F/F In Stock £5.44
9KMM StarTech.com 4 Port PCI Express 2.0 SATA III 6Gbps RAID Controller Card with HyperDuo SSD Tiering In Stock £66.34
9KMM StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £69.01
