StarTech.com 3 Port PCI Low Profile 1394a FireWire Adapter Card
Customer rating: 5.0* (Write a review)
Quicklinx: 3ZQYWS00 Mfr#: PCI1394_2LP
  • Windows 8 (32/64 bits)
Add 2 external and 1 internal FireWire400 port to any computer with a low profile PCI slot. This 3 Port PCI Low-Profile/Half-Height 1394a FireWire Adapter Card turns a motherboard PCI slot into two external IEEE 1394a FireWire slots (1x6-pin, 1x4-pin), and provides an internal (6-pin) FireWire port that can be used in place of the external 6-pin connector - a cost-effective solution that lets you connect any FireWire 400 device to your desktop computer.
Compatible with either Mac or PC computers, the 1394a FireWire card can be installed in small/micro form factor computer cases, and includes both standard and low profile/half-height brackets for easy installation.
A practical solution for connecting iPods, MP3 players, portable drives, digital camcorders and more to your desktop computer, the FireWire 400 adapter card supports hot-swappable connectivity, allowing you to plug, unplug, and swap your FireWire peripherals with ease.
A versatile FireWire video editing solution, the adapter card can be installed in a PCI 5V or PCI-x 3.3V slot.
StarTech.com 3 Port PCI Low Profile 1394a FireWire Adapter Card - FireWire adapter - PCI - 3 ports
FireWire adapter
Plug-in card - low profile
Interface (Bus) Type
PCI
Ports Qty
3 ports
Firewire
Data Transfer Rate
400 Mbps
Microsoft Windows 98 Second Edition, Linux, Microsoft Windows 2000, Apple MacOS X, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
FireWire adapter - 3 ports
PCI
Wired
IEEE 1394 (FireWire)
Data Transfer Rate
400 Mbps
2 x FireWire - 6 PIN FireWire (external) , 1 x FireWire - 6 PIN FireWire (internal)
Compatible Slots
1 x PCI - low-profile
1 x IEEE 1394 cable - 1.8 m
Limited warranty - lifetime
Customer reviews
Write a review for the StarTech.com 3 Port PCI Low Profile 1394a FireWire Adapter Card here!
Great Firewire card for slimline desktops
Reviewed by Grumpy. Review Posted 16/07/2007
Having spoken to 8 Dell 'customer service' people who didn't know what a Dell Dimension 3100c was I contcted dabs who suggested a low profile firewire card might fit as i had already tried a full size one that didn't. Fitted perfectly and is now up and running. Great product and as usual great service.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Vista 64 plug & play
Reviewed by Sam. Review Posted 02/12/2008
I did have some concerns regarding this card and Vista64, however upon receipt I installed the card and it was immediately recognised by the OS and installed without any hassle whatsoever. I was up and running within 2 minutes, direct integration into Adobe Premiere Pro CS3 (I have not yet tried the included software) allowing me DV camera access and control. The low profile nature meant that I did not in any way obstruct the fan of my neighbouring graphics card, as all my other PCI slots were in use.
If a product does exactly what I want and causes me no hassle - then I can't rate it lower than 5/5!
Definitely recommended.
  • Overall 5*
  • Ease of use 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
