Add 2 native FireWire 800 ports to your computer through a PCI Express expansion slot. This 3 Port PCI Express FireWire adapter card can be installed in a PCI Express slot to add two IEEE1394b (FireWire 800 - 9 pin) ports and one IEEE1394a (FireWire 400 - 6 pin) port, providing broad compatibility with a wide range of FireWire devices (e.g. DV camcorders, external hard drives, digital cameras, etc.).
The 2b, 1a card features a native (single chip) PCI Express chipset - resulting in faster, more reliable and cost effective performance than expansion cards that utilize a "bridge" chip.
                Efficient data transferWith a maximum data transfer rate of 800 Mbps, this FireWire card adapter ensures quick data exchange between connected devices.
                Versatile connectivity optionsEquipped with two IEEE 1394b ports and one IEEE 1394 port, this adapter allows for multiple device connections.
                Mac compatibilityThis FireWire card adapter is designed for compatibility with Mac systems, suitable for users with Apple devices.
                Flexible cable lengthThe included external 1.5 m IEEE 1394b cable provides ample length for placement of connected devices in your workspace.
                Reliable compliance standardsThe card meets UL and FCC compliance, ensuring adherence to recognized safety and performance standards.
- StarTech.com 3 Port 2b 1a 1394 PCI Express FireWire Card Adapter - 1394 FW PCIe FireWire 800 / 400 Card (PEX1394B3) - FireWire adapter - PCIe - 2 ports
- FireWire adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express x1
- Bus Voltage
- 3.3 V
- 1.8 cm x 8.5 cm x 12 cm
- 48 g
- Ports Qty
- 2 ports
- Auxiliary Ports
- 1 x IEEE 1394 (FireWire)
- Data Link Protocol
- FireWire 800
- Data Transfer Rate
- 800 Mbps
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Linux 3.5.x or later LTS versions only, Apple macOS 13.0
- Limited lifetime warranty
- Designed For
- P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16
- FireWire adapter - 2 ports
- Form Factor
- Plug-in card
- PCI Express x1
- Bus Voltage
- 3.3 V
- Connectivity Technology
- Wired
- IEEE 1394b (FireWire 800)
- Auxiliary Ports
- 800 Mbps
- 2 x FireWire 800 - 9 pin FireWire 800 , 1 x FireWire - 6 PIN FireWire
- Compatible Slots
- 1 x PCI Express x1
- Cables Included
- 1 x IEEE 1394b cable (external) - 1.5 m
- UL, FCC
- Software Included
- Drivers & Utilities
- OS Required
- 1.8 cm
- 8.5 cm
- 12 cm
- 48 g
- Limited warranty - lifetime
- Designed For
|  | StarTech.com 3 Port 2b 1a Low Profile 1394 PCI Express FireWire Card Adapter | In Stock | £47.64 |
|  | StarTech.com 3 Port 2b 1a 1394 Mini PCI Express FireWire Card Adapter | In Stock | £26.08 |
|  | StarTech.com 10 ft 1394b Firewire 800 Cable 9-9 M/M | In Stock | £11.47 |
