StarTech.com 3 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - White
Quicklinx: 8XCGWS00 Mfr#: MDP2DVIMM3W
Connect a DVI display to a Mini DisplayPort-equipped PC or MAC over a short 3 foot distance, with a tidy installation - White. The MDP2DVIMM3W Mini DisplayPort to DVI Adapter Cable lets you directly connect your Mini DP video source (Desktop PC, Laptop, Ultrabook etc.) to a DVI monitor, projector, eliminating the expense of having to upgrade to a Mini DisplayPort-capable monitor.
The adapter cable is 3 feet (1m) in length, and features male-to-male connectors, allowing you to connect your Mini DisplayPort source directly to a DVI display with no additional cabling required.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port, the adapter supports resolutions up to 1920x1200 (WUXGA).
MDP2DVIMM3Wis a passive adapter that requires a dual-mode DisplayPort port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
StarTech.com 3 ft Mini DisplayPort to DVI Adapter Cable - Mini DP to DVI Video Converter - MDP to DVI Cable for Mac / PC 1920x1200 - White (MDP2DVIMM3W) - DisplayPort cable - 91.44 cm
DisplayPort cable
Thumbscrews
Length
91.44 cm
Connector
Mini DisplayPort - male
Connector (Second End)
DVI-D - male
FCC, RoHS
White
Image Colour Disclaimer
The displayed product image may be a different colour
3-year warranty
DisplayPort cable
Thumbscrews
Length
91.44 cm
White
Connector
24+1 pin digital DVI - male
FCC, RoHS
3-year warranty
8XCG StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £11.80
8XCG StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £21.80
8XCG StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £22.37
8XCG StarTech.com Mini DisplayPort to DVI Video Adapter Converter In Stock £9.72
8XCG StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £9.22
8XCG StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £17.08
8XCG StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M In Stock £23.80
8XCG StarTech.com Mini DisplayPort to DVI Video Adapter Converter - Black Mini DP to DVI - 1920x1200 In Stock £9.88
8XCG StarTech.com 3 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black In Stock £12.06
8XCG StarTech.com 6 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black In Stock £13.79
