Connect a DVI display to a Mini DisplayPort-equipped PC or MAC over a short 3 foot distance, with a tidy installation - Black. The MDP2DVIMM3BMini DisplayPort to DVI Adapter Cable lets you directly connect your Mini DP video source (Desktop PC, Laptop, Ultrabook, etc.) to a DVI monitor or projector, eliminating the expense of having to upgrade to a Mini DisplayPort-capable monitor.
The adapter cable is 3feet (1m) in length, and features male-to-male connectors, allowing you to connect your Mini DisplayPort source directly to a DVI display device with no additional cabling required.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port, the adapter supports resolutions up to 1920x1200 (WUXGA).
MDP2DVIMM3B is a passive adapter that requires a dual-mode DisplayPortport (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
- StarTech.com 3 ft Mini DisplayPort to DVI Adapter Cable - Mini DP to DVI Video Converter - MDP to DVI Cable for Mac / PC 1920x1200 - Black (MDP2DVIMM3B) - DisplayPort cable - 91.44 cm
- DisplayPort cable
- Thumbscrews
- Length
- 91.44 cm
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- DVI-D - male
- FCC, RoHS
- Black
- 3-year warranty
- DisplayPort cable
- Thumbscrews
- Length
- 91.44 cm
- Black
- Connector
- 24+1 pin digital DVI - male
- FCC, RoHS
- 3-year warranty
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £11.80 |
StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M | In Stock | £21.80 |
StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M | In Stock | £22.37 |
StarTech.com Mini DisplayPort to DVI Video Adapter Converter | In Stock | £9.72 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £9.22 |
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £17.08 |
StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M | In Stock | £23.80 |
StarTech.com Mini DisplayPort to DVI Video Adapter Converter - Black Mini DP to DVI - 1920x1200 | In Stock | £9.88 |
StarTech.com 3 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black | In Stock | £12.06 |
StarTech.com 6 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black | In Stock | £13.79 |
