StarTech.com 3 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black
Quicklinx: 8VTVWS00 Mfr#: MDP2DVIMM3B
£11.84 ex VAT
£14.20 inc VAT
Connect a DVI display to a Mini DisplayPort-equipped PC or MAC over a short 3 foot distance, with a tidy installation - Black. The MDP2DVIMM3BMini DisplayPort to DVI Adapter Cable lets you directly connect your Mini DP video source (Desktop PC, Laptop, Ultrabook, etc.) to a DVI monitor or projector, eliminating the expense of having to upgrade to a Mini DisplayPort-capable monitor.
The adapter cable is 3feet (1m) in length, and features male-to-male connectors, allowing you to connect your Mini DisplayPort source directly to a DVI display device with no additional cabling required.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port, the adapter supports resolutions up to 1920x1200 (WUXGA).
MDP2DVIMM3B is a passive adapter that requires a dual-mode DisplayPortport (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
StarTech.com 3 ft Mini DisplayPort to DVI Adapter Cable - Mini DP to DVI Video Converter - MDP to DVI Cable for Mac / PC 1920x1200 - Black (MDP2DVIMM3B) - DisplayPort cable - 91.44 cm
DisplayPort cable
Thumbscrews
Length
91.44 cm
Connector
Mini DisplayPort - male
Connector (Second End)
DVI-D - male
FCC, RoHS
3-year warranty
DisplayPort cable
Thumbscrews
Length
91.44 cm
Connector
24+1 pin digital DVI - male
FCC, RoHS
3-year warranty
8VTV StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £11.76
8VTV StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £21.60
8VTV StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £21.83
8VTV StarTech.com Mini DisplayPort to DVI Video Adapter Converter In Stock £10.18
8VTV StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £9.00
8VTV StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £17.10
8VTV StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M In Stock £23.23
8VTV StarTech.com Mini DisplayPort to DVI Video Adapter Converter - Black Mini DP to DVI - 1920x1200 In Stock £9.75
8VTV StarTech.com 3 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black In Stock £11.84
8VTV StarTech.com 6 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black In Stock £13.53
8VTV StarTech.com 10 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 Black In Stock £18.47
