StarTech.com 10 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 White
Quicklinx: 8Y6NWS00 Mfr#: MDP2DVIMM10W
Connect a DVI display to a Mini DisplayPort-equipped PC or MAC over a longer 10 foot distance - White. The MDP2DVIMM10W Mini DisplayPortto DVI Adapter Cable lets you directly connect your Mini DP video source (desktop PC, laptop, Ultrabook, etc.) to a DVI monitor or projector, eliminating the expense of having to upgrade to a Mini DisplayPort-capable monitor.
The adapter cable is 10feet (3m) in length, and features male-to-male connectors, allowing you to connect your Mini DisplayPort source directly to a DVI display with no additional cabling required.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over ThunderboltI/O port, the adapter supports resolutions up to 1920x1200 (WUXGA).
MDP2DVIMM10Wis a passive adapter that requires a dual-mode DisplayPortport (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
StarTech.com 10 ft Mini DisplayPort to DVI Adapter Cable MDP to DVI - White - DisplayPort cable - 3.04 m
DisplayPort cable
Thumbscrews
Length
3.04 m
Connector
Mini DisplayPort - male
Connector (Second End)
DVI-D - male
FCC, RoHS
White
Image Colour Disclaimer
The displayed product image may be a different colour
3-year warranty
DisplayPort cable
Thumbscrews
Length
3.04 m
White
Connector
24+1 pin digital DVI - male
FCC, RoHS
3-year warranty
8Y6N StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £11.80
8Y6N StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £21.80
8Y6N StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £22.37
8Y6N StarTech.com Mini DisplayPort to DVI Video Adapter Converter In Stock £9.72
8Y6N StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £9.22
8Y6N StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £17.60
8Y6N StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M In Stock £23.80
8Y6N StarTech.com Mini DisplayPort to DVI Video Adapter Converter - Black Mini DP to DVI - 1920x1200 In Stock £9.88
8Y6N StarTech.com 3 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black In Stock £12.06
8Y6N StarTech.com 6 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black In Stock £13.79
8Y6N StarTech.com 10 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 Black In Stock £18.85
