StarTech.com 3 ft Coax High Resolution Monitor VGA Cable -  HD15 M/M
Quicklinx: 6BB9WS00 Mfr#: MXT101MMHQ3
This 3ft High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male to male coaxial VGA cable eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 3 ft Coax High Resolution Monitor VGA Cable - HD15 M/M - VGA cable - 0.9 m
VGA cable
Triple shielded twisted pair coaxial
Molded, ferrite bead
Length
0.9 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
P/N: BNDDKTCHVPRS, CDP2HVGUASPD, CDP2VGAFC, CDP2VGASA, CDP2VGAUACP, CDP2VGAUCP, CDP2VGAUCPW, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDB, CDPVGDVHDMDP, DKT30CHVCM, DKT30CHVGPD, DKT30CHVPD2, DKT30CHVW, DKT30CVAGPD, DP2VGA3X5, HD2DPVGADVI, USB32HDVGA, USB32VGCAPRO, USBC2VGCAPRO
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
0.9 m
Connector
P/N: BNDDKTCHVPRS, CDP2HVGUASPD, CDP2VGA, CDP2VGAFC, CDP2VGASA, CDP2VGAUACP, CDP2VGAUCP, CDP2VGAUCPW, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDB, CDPVGDVHDMDP, DKT30CHV, DKT30CHVCM, DKT30CHVGPD, DKT30CHVPD2, DKT30CHVW, DKT30CVAGPD, DP2VGA, DP2VGA2, DP2VGA3, DP2VGA3X5, DP2VGAA, DP2VGDVHD, DVI2VGAE, DVI92030202L, DVISPL1VV, DVIVGAMF, DVIVGAMFBK, HD2DPVGADVI, HD2VGAA2, HD2VGAE2, HD2VGAMICRO, HDVGADP2HD, MCHD2VGAE2, MDP2HDVGA, MDP2HDVGAW, MDP2VGA, MDP2VGA2, MDP2VGAAMM2M, MDP2VGAAMM3M, MDP2VGAW, MNHD2VGAE2, MSTP3MDPUGBK, MSTS3MDPUGBK, RACKCONS1908, SV1631DUSBUK, SV221NANOU, SV231DDVDUA, SV231UAF, SV231USB, SV231USBLC, SV431DDVDUA, SV431USB, SV565USAGB, USB2VGAE2, USB2VGAE3, USB2VGAPRO2, USB31GEVG, USB32HDVGA, USB32VGAEH, USB32VGAEH3, USB32VGAES, USB32VGAPRO, USB32VGAV, USB32VGCAPRO, USBC2VGCAPRO, VGA2VID, VGASPL1VV
