StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F
Quicklinx: 76VDWS00 Mfr#: USBEXTAA3BK
Length: 91cm
More than 50 in stock
£1.27 ex VAT
£1.52 inc VAT
The USBEXTAA3BK 3-foot USB Extension Cable (A-A) features 1 USB A male connector and 1 USB A female connector, extending the connection between USB 2.0 devices by up to 3 feet - an ideal solution for better placement of peripheral devices, or adding flexibility to existing USB ports. This high quality USB extension cable is fully rated for use with USB 1.1 and USB 2.0 devices.
StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F - USB extension cable - 91 cm
USB extension cable
Double shielded
Length
91 cm
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
USB / USB 2.0
P/N: 35FCREADBK3, SV221NANOU
USB extension cable
Double shielded
American Wire Gauge (AWG)
24/28
Length
91 cm
Connector
USB / USB 2.0, RoHS
76VD StarTech.com 6 ft Mini USB Cable - A to Mini B In Stock £3.17
76VD StarTech.com 15 ft USB 2.0 A to B Cable - M/M In Stock £4.33
76VD StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.90
76VD StarTech.com 1 ft Panel Mount USB Cable A to A - F/M In Stock £4.21
76VD StarTech.com 1 ft Mini USB 2.0 Cable - A to Mini B - M/M In Stock £3.18
76VD StarTech.com 6 ft Transparent USB 2.0 Cable - A to B In Stock £3.70
76VD StarTech.com 3 ft A Right Angle to B Right Angle USB Cable - M/M In Stock £4.14
76VD StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F In Stock £3.83
76VD StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £1.27
76VD StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £3.58
76VD StarTech.com 6in USB 2.0 Extension Adapter Cable A to A - M/F In Stock £3.07
76VD StarTech.com 3m White USB 2.0 Extension Cable A to A - M/F In Stock £5.23
76VD StarTech.com 1m White USB 2.0 Extension Cable A to A - M/F In Stock £4.50
76VD StarTech.com 2m White USB 2.0 Extension Cable A to A - M/F In Stock £4.88
Length: 91cm
Price Range Ex VAT: 0 - 50
