StarTech.com 1 ft Panel Mount USB Cable A to A - F/M
Quicklinx: 6BBZWS00 Mfr#: USBPNLAFAM1
Length: 30cm
More than 50 In Stock
£4.93 ex VAT
£5.91 inc VAT
Add an external panel mount USB connection to a PC or faceplate. The USBPNLAFAM1 1ft Panel Mount USB Cable provides a well-secured, easy to access USB-A port on your PC or on a faceplate, allowing you to customize your systems to suit your needs. Perfect for podiums, kiosks and other solutions where added access to USB devices is required.
The adapter features one male USB-A connector and one female panel mount USB-A port and gives you an extension of 1ft, enabling you to place the cable as needed within the system case.
StarTech.com 1 ft Panel Mount USB Cable A to A - F/M - USB extension cable - USB (M) to USB (F) - USB 2.0 - 1 ft - molded, thumbscrews - black - USBPNLAFAM1 - USB extension cable - USB to USB - 30 cm
USB extension cable
Molded, thumbscrews
Length
30 cm
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
USB / USB 2.0
P/N: UUSBOTG
USB extension cable
Molded, thumbscrews
Length
30 cm
Connector
USB / USB 2.0, RoHS
P/N: UUSBOTG
6BBZ StarTech.com 1 ft Panel Mount USB Cable A to A - F/M In Stock £4.93
6BBZ StarTech.com 3ft DisplayPort Panel Mount Cable - F/M In Stock £13.69
6BBZ StarTech.com 3 ft Standard HDMI Cable for Panel Mount - F/M In Stock £9.35
6BBZ StarTech.com 3 ft 20 pin DisplayPort Extension Panel Mount Cable - M/F In Stock £15.06
6BBZ StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F In Stock £5.02
6BBZ StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.06
6BBZ StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.29
6BBZ StarTech.com 2 Port USB 3.0 A Female Slot Plate Adapter In Stock £18.52
6BBZ StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £14.46
6BBZ StarTech.com 3 ft Panel Mount USB Cable A to A - F/M In Stock £5.34
6BBZ StarTech.com 2 ft Panel Mount USB Cable A to A - F/M In Stock £5.12
Length: 30cm
