StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F
Quicklinx: 76VDWS00 Mfr#: USBEXTAA3BK
Length: 91cm
More than 50 In Stock
£4.06 ex VAT
£4.87 inc VAT
The USBEXTAA3BK 3-foot USB Extension Cable (A-A) features 1 USB A male connector and 1 USB A female connector, extending the connection between USB 2.0 devices by up to 3 feet - an ideal solution for better placement of peripheral devices, or adding flexibility to existing USB ports. This high quality USB extension cable is fully rated for use with USB 1.1 and USB 2.0 devices.
  • Reliable Construction
    This USB extension cable is built with double shielding, significantly reducing interference and ensuring a stable connection for your devices.
  • Convenient Length
    At 3 ft, this extension cable provides just the right reach to connect USB peripherals without cluttering your workspace.
  • Secure Connectors
    Featuring 4-pin USB Type-A connectors, this cable provides a firm connection, minimizing the risk of disconnection during use.
  • Wide Compatibility
    The cable is compatible with various Mac devices, making it a versatile solution for users with different USB needs.
StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F - 3 ft USB A to A Extension Cable - 3ft USB 2.0 Extension cord (USBEXTAA3BK) - USB extension cable - USB to USB - 91 cm
USB extension cable
Double shielded
Length
91 cm
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
USB / USB 2.0
P/N: 35FCREADBK3, ICUSB2321F, ICUSB232PRO, ICUSB232V2, LTUB1MBK, MSDREADU2OTG, ST4300USB3, ST4300USB3EU, ST4300USB3GB, SV221NANOU, UUSBOTG
USB extension cable
Double shielded
American Wire Gauge (AWG)
24/28
Length
91 cm
Connector
USB / USB 2.0, RoHS
76VD StarTech.com 1 ft Panel Mount USB Cable A to A - F/M In Stock £5.29
76VD StarTech.com Mini USB to Micro USB Adapter In Stock £3.67
76VD StarTech.com 6in Mini USB 2.0 Cable - A to Mini B In Stock £4.07
76VD StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F In Stock £5.00
76VD StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.06
76VD StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.19
76VD StarTech.com 6in Micro USB Cable - A to Micro B In Stock £4.99
76VD StarTech.com 6in USB 2.0 Extension Adapter Cable A to A - M/F In Stock £4.92
76VD StarTech.com 6in Micro USB to Mini USB Adapter Cable M/F In Stock £6.13
76VD StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £14.23
76VD StarTech.com 3m White USB 2.0 Extension Cable A to A - M/F In Stock £6.37
76VD StarTech.com 1m White USB 2.0 Extension Cable A to A - M/F In Stock £5.51
76VD StarTech.com 3ft Right Angle Micro-USB Cable In Stock £5.22
76VD StarTech.com 6ft Right Angle Micro-USB Cable In Stock £6.18
76VD StarTech.com 3ft Micro-USB Charging Cable In Stock £4.95
76VD StarTech.com 3 ft Micro-USB Charging Cable In Stock £4.62
76VD StarTech.com 6 ft Micro-USB Charging Cable In Stock £7.11
76VD StarTech.com 0.5m Angled Micro USB Cable In Stock £4.41
76VD StarTech.com 0.5m Angled Micro USB Cable In Stock £4.71
Length: 91cm
