StarTech.com 3 ft 20 pin DisplayPort Extension Panel Mount Cable - M/F
Quicklinx: 76RLWS00 Mfr#: DPPNLFM3PW
Type: DisplayPort
Length: 91cm
£15.45 ex VAT
£18.54 inc VAT
The DPPNLFM3PW 3ft DisplayPort Extension Panel Mount Cable features one DP male connector and one panel mount DP female connector, providing a well-secured, easy to access DisplayPort connection on your PC or faceplate, and allowing you to customize your systems to suit your needs. If power is required, the DisplayPort Cable uses all 20 pins and can deliver power accordingly.
  • Reliable connectivity
    The 20 pin DisplayPort connection provides a dependable link between devices, ensuring high-quality signal transmission for audio and video.
  • Durable design
    Constructed with molded connectors, this cable is designed to withstand everyday wear and tear, making it suitable for various applications.
  • Secure connection
    The latched connection mechanism prevents accidental disconnections, delivering uninterrupted performance during use.
  • Power integration
    The integrated power connectors simplify connectivity by providing additional power to devices when needed, enhancing usability.
  • Compliance standards
    This cable meets RoHS and NEC-CMG compliance standards, ensuring it is safe for both the environment and user.
StarTech.com 3 ft / 91 cm 20 pin DP DisplayPort Extension Panel Mount Cable - DisplayPort to DisplayPort - Male to Female (DPPNLFM3PW) - DisplayPort cable - 91 cm
DisplayPort cable
Latched, molded, integrated power connectors
Length
91 cm
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - female
RoHS, NEC-CMG
DisplayPort cable
American Wire Gauge (AWG)
28
Length
91 cm
Connector
20 pin DisplayPort - male
20 pin DisplayPort - female
RoHS, NEC-CMG
76RL StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £11.80
76RL StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F In Stock £10.81
76RL StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £21.80
76RL StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £22.37
76RL StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £16.94
76RL StarTech.com 1 ft Panel Mount USB Cable A to A - F/M In Stock £5.29
76RL StarTech.com 1 ft Panel Mount USB Cable - USB A to Motherboard Header Cable F/F In Stock £5.55
76RL StarTech.com 3 ft 20 pin DisplayPort Extension Panel Mount Cable - M/F In Stock £15.45
76RL StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.58
76RL StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £13.72
Type: DisplayPort
Length: 91cm
