StarTech.com 1 ft Panel Mount USB Cable - USB A to Motherboard Header Cable F/F
Quicklinx: 6BC0WS00 Mfr#: USBPNLAFHD1
Length: 30cm
£5.74 ex VAT
£6.88 inc VAT
This 1ft USB to Panel mount USB cable features a 5-pin motherboard header connection on one end and a panel mount USB A (female) port on the other, providing a simple and easy to access USB 2.0 port on a panel mount receptacle.
The USB panel mount cable offers a convenient solution for connecting bootable thumb drives or authentication fobs etc. to the motherboard USB connection.
StarTech.com 1 ft Panel Mount USB Cable - USB A to Motherboard Header Cable Adapter F/F - USB 2.0 internal Cable (USBPNLAFHD1) - USB internal to external cable - USB to 5 pin USB 2.0 header - 30 cm
Thumbscrews
Length
30 cm
Connector
4 pin USB Type A - female
Connector (Second End)
5 pin USB 2.0 header - female
USB / USB 2.0
Thumbscrews
Length
30 cm
Connector
USB / USB 2.0, RoHS
Length: 30cm
