The DPPNLFM3PW 3ft DisplayPort Extension Panel Mount Cable features one DP male connector and one panel mount DP female connector, providing a well-secured, easy to access DisplayPort connection on your PC or faceplate, and allowing you to customize your systems to suit your needs. If power is required, the DisplayPort Cable uses all 20 pins and can deliver power accordingly.
Reliable connectivity
The 20 pin DisplayPort connection provides a dependable link between devices, ensuring high-quality signal transmission for audio and video. -
Durable design
Constructed with molded connectors, this cable is designed to withstand everyday wear and tear, making it suitable for various applications. -
Secure connection
The latched connection mechanism prevents accidental disconnections, delivering uninterrupted performance during use. -
Power integration
The integrated power connectors simplify connectivity by providing additional power to devices when needed, enhancing usability. -
Compliance standards
This cable meets RoHS and NEC-CMG compliance standards, ensuring it is safe for both the environment and user.
- StarTech.com 3 ft / 91 cm 20 pin DP DisplayPort Extension Panel Mount Cable - DisplayPort to DisplayPort - Male to Female (DPPNLFM3PW) - DisplayPort cable - 91 cm
- DisplayPort cable
- Latched, molded, integrated power connectors
- Length
- 91 cm
- Connector
- DisplayPort - male
- Connector (Second End)
- DisplayPort - female
- RoHS, NEC-CMG
- Black
- Limited lifetime warranty
- DisplayPort cable
- American Wire Gauge (AWG)
- 28
- Length
- 91 cm
- Black
- Connector
- 20 pin DisplayPort - male
- 20 pin DisplayPort - female
- RoHS, NEC-CMG
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £11.80 |
StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F | In Stock | £10.81 |
StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M | In Stock | £21.80 |
StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M | In Stock | £22.37 |
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £16.94 |
StarTech.com 1 ft Panel Mount USB Cable A to A - F/M | In Stock | £5.29 |
StarTech.com 1 ft Panel Mount USB Cable - USB A to Motherboard Header Cable F/F | In Stock | £5.55 |
StarTech.com 3 ft 20 pin DisplayPort Extension Panel Mount Cable - M/F | In Stock | £15.45 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £13.58 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £13.72 |
