StarTech.com 3.5in Drive Bay IDE to Single CF SSD Adapter Card Reader
Quicklinx: 6BCSWS00 Mfr#: 35BAYCF2IDE
£19.40 ex VAT
£23.28 inc VAT
Providing a stable platform for use with Compact Flash (I and II) and IBM Micro-drive media, this Compact Flash Card to IDE Adapter with 3.5" Bay Enclosure installs easily through a simple connection to an available IDE port, for use in either the front or back of a host computer.
  • Versatile compatibility
    This card reader supports a range of flash memory types, including CompactFlash Card type I, CompactFlash Card type II, and Microdrive, providing flexibility for various storage needs.
  • Easy installation
    Designed for front accessibility, the adapter card reader can be installed in a compatible 3.5-inch internal bay, simplifying integration with existing systems.
  • Included accessories
    The package comes with essential accessories including a 3.5-inch bay adapter and a rear expansion slot bracket, ensuring that all components needed for installation are at hand.
  • Compliance and standards
    This product adheres to FCC and RoHS standards, ensuring it meets safety and environmental regulations for reliable usage.
StarTech.com 3.5in Drive Bay IDE to Single CF SSD Adapter Card Reader (35BAYCF2IDE) - card reader - IDE
Card reader - internal
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Microdrive
Host Interface
IDE
Required Bay
3.5" internal
Host Interface
IDE
Required Bay
3.5" internal
Memory Card
(max)
Required Ports
1 x 40 PIN IDC , 1 x 44 PIN IDC
3.5-inch bay adapter, rear expansion slot bracket
FCC, RoHS
6BCS StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter In Stock £5.84
6BCS StarTech.com 3.5in Drive Bay IDE to Single CF SSD Adapter Card Reader In Stock £19.40
Supported Formats: Microdrive
Supported Formats: CompactFlash Card type II
Interface: IDE
