StarTech.com 2x1 VGA + HDMI to VGA Converter Switch w/ Priority Switching – 1080p
Quicklinx: 9ZJHWS00 Mfr#: VS221HD2VGA
Type: Video/audio switch
Connectivity: VGA
Ports: [N/A]
£140.51 ex VAT
£168.61 inc VAT
Share a VGA display/projector between a VGA and HDMI audio/video source, with priority switching. The VS221HD2VGA VGA & HDMI Auto Switch lets you connect two distinct A/V sources - one VGA and one HDMI to the same VGA monitor or projector, and automatically or manually switch between which video source is displayed. This multi-input switch supports video resolution up to 1920x1200 (1080p) and includes mounting hardware for a tidy, professional installation.
The A/V switch features built-in HDMI conversion, enabling you to connect an HDMI as well as a VGA video source to the same VGA display, without the use of additional adapters or scalers. The switch also supports EDID pass-through, EDID copy, and EDID emulation to ensure your HDMI and VGA native resolutions will be maintained between both source connections.
The VS221HD2VGA ensures hassle-free operation with support for priority port selection, enabling you to choose which port should be selected first by sequence. Once the device connected to your specific port is activated, the switch will then automatically select that port.
This A/V switch has been designed with the boardroom and classroom in mind. The VS221HD2VGA features VGA and HDMI inputs to support a wide range of devices, and the built-in converter makes it easy to connect to a display without the use of additional adapters. Plus, priority switching encourages on-the-fly collaboration among students or co-workers, by making it easy to share your projector between multiple source devices.
Digitally encrypted content from the HDMI video source will not be displayed on the VGA display. If you are looking for a similar device with HDMI output, please see our VS221VGA2HD.
If you are looking for a similar device with HDMI output, please see the VS221VGA2HD.
StarTech.com 2x1 VGA + HDMI to VGA Converter Switch w/ Priority Switching - Multi-format VGA and HDMI to VGA Selector - 1080p (VS221HD2VGA) - video/audio switch
Video/audio switch
Subtype
VGA
P/N: SVA5N3NEUA
Video/audio switch
Enclosure Type
Desktop
Subtype
VGA
1 x VGA input HD-15 , 1 x HDMI input , 1 x VGA output
External power adapter
Mounting brackets
FCC, RoHS
P/N: SVA5N3NEUA
9ZJH StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.52
9ZJH StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.99
9ZJH StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.83
9ZJH StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.79
9ZJH StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £4.68
9ZJH StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £11.60
9ZJH StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £8.66
9ZJH StarTech.com Conference Table Connectivity Box – HDMI / VGA / Mini DisplayPort to HDMI Output In Stock £191.07
9ZJH StarTech.com 2x1 HDMI VGA to HDMI Converter In Stock £127.00
9ZJH StarTech.com 4-Port 4K HDMI Video Switch In Stock £121.24
9ZJH StarTech.com 2-Port 4K HDMI Video Switch In Stock £90.94
9ZJH StarTech.com 2x2 HDMI Matrix Switch - 4K In Stock £138.09
9ZJH StarTech.com DisplayPort VGA HDMI Converter Switch In Stock £243.98
9ZJH StarTech.com DC Power Adapter - 5V, 3A In Stock £12.22
Connectivity: VGA
Ports: [N/A]
