StarTech.com Conference Table Connectivity Box – HDMI / VGA / Mini DisplayPort to HDMI Output
Quicklinx: 9Q9YWS00 Mfr#: BOX4HDECP
£191.07 ex VAT
£229.28 inc VAT
Install an HDMI, VGA, mDP & Composite Audio/Video access panel into the surface of a table, and output to an HDMI display or projector, with a discreet hideaway design
The BOX4HDECP Automatic Conference Table Connectivity Box features a concealed, in-table design that lets you connect a VGA, Mini DisplayPort, HDMI or composite video source device to an HDMI display or projector.
When the video switch isn't in use, you can simply slide the stylish cover panel over the connectors, hiding them inside the table or podium surface. Convenient Accessibility Presenters can conveniently share content from their own device with the table top switch automatically converting any attached audio/video source device source into a single HDMI output.
The switch box also offers stylish integration into your modern boardroom or classroom with a discreet hideaway panel. For added convenience the BOX4HDECP features a USB charging port to charge your mobile device and an Ethernet pass-through port for Internet connectivity in boardrooms where Wi-Fi is not available.
Connectivity Options With support for different video inputs including: HDMI, VGA, Mini DisplayPort, and composite, the video switch ensures support for almost any laptop, Ultrabook or mobile device such as MacBook, Microsoft Surface Pro 2 & 3, and Lenovo X1. The switch panel even works with legacy audio/video devices such as DVD player, and supports the use of video adapters for your iPhone or iPad.
Collaborate Easily The A/V switch makes your large display accessible to any presenter's video source device, by installing directly into the surface of your table or podium, and automatically outputs the most recently connected video source. Plus, support for high-definition video resolutions up to 1920x1080 (1080p) ensures the quality of your presentation is maintained.
The BOX4HDECP is backed by a StarTech.com 2-year warranty, and free lifetime technical support.
  • Convenient accessibility
    Presenters can conveniently share content from their own device with the table top switch automatically converting any attached audio/video source device source into a single HDMI output. The switch box also offers stylish integration into your modern boardroom or classroom with a discreet hideaway panel. For added convenience the BOX4HDECP features a USB charging port to charge your mobile device and an Ethernet pass-through port for Internet connectivity in boardrooms.
  • Collaborate easily
    The A/V switch makes your large display accessible to any presenter's video source device, by installing directly into the surface of your table or podium, and automatically outputs the most recently connected video source. Plus, support for high-definition video resolutions up to 1920 x 1080 (1080p) ensures the quality of your presentation is maintained.
StarTech.com Conference Table Connectivity Pop up Box with AV and Data Ports - HDMI, VGA, Component, MDP to HDMI Output (BOX4HDECP) - mounting plate
Mounting plate - HD-15, RCA X 2, RJ-45, mini-phone stereo 3.5 mm, RCA, HDMI, USB Type A, mini-DisplayPort
Package Content
External power adapter
17 cm x 10 cm x 10 cm
1.661 kg
FCC, RoHS
Mounting plate
Package Content
17 cm
10 cm
10 cm
1.661 kg
Cabling & Wiring
Connector Provided
1 x 19 pin HDMI Type A male , 2 x RJ-45 female , 1 x 19 pin HDMI Type A female , 1 x 15 pin HD D-Sub (HD-15) female , 1 x mini-phone stereo 3.5 mm female , 1 x RCA female , 1 x Mini DisplayPort female , 1 x RCA x 2 female , 1 x 4 pin USB Type A
FCC, RoHS
10 - 85% (non-condensing)
9Q9Y StarTech.com High Resolution VGA to Composite (RCA) or S-Video Converter - PC to TV In Stock £87.60
9Q9Y StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.27
9Q9Y StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.99
9Q9Y StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.83
9Q9Y StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.79
9Q9Y StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £11.60
9Q9Y StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £8.66
9Q9Y StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £15.20
9Q9Y StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £15.79
9Q9Y StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.95
9Q9Y StarTech.com 3m (10ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £18.47
9Q9Y StarTech.com 0.3m (1ft) Short High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £6.82
9Q9Y StarTech.com Conference Table Connectivity Box – HDMI / VGA / Mini DisplayPort to HDMI Output In Stock £191.07
9Q9Y StarTech.com 2x1 HDMI VGA to HDMI Converter In Stock £127.00
9Q9Y StarTech.com DisplayPort VGA HDMI Converter Switch In Stock £243.98
9Q9Y StarTech.com Table Cable Management Box In Stock £51.56
9Q9Y StarTech.com Conference Table Box for A/V In Stock £224.34
9Q9Y StarTech.com Table Box Laptop Dock & Power In Stock £556.23
Type: Mounting Kits
Stock Status: While stocks last
Stock Status: Clearance
