StarTech.com 2x1 HDMI VGA to HDMI Converter
Quicklinx: B458WS00 Mfr#: VS221VGA2HD
32 in stock
£128.11 ex VAT
£153.73 inc VAT
Share an HDMI display/projector between a VGA and HDMI audio/video source, with automatic and priority switching. The VS221VGA2HD HDMI & VGA Auto Switch lets you connect an HDMI and a VGA audio/video source to the same HDMI display or projector, and automatically or manually switch between which video source is displayed. The multi-input A/V switch supports video resolution up to 1920x1200 (1080p) and includes mounting hardware for a tidy professional installation.
The A/V switch features built-in VGA conversion, enabling you to connect an HDMI and a VGA video source to the same HDMI display without the use of additional adapters or scalers. The switch also supports EDID pass-through, EDID copy, and EDID emulation to ensure your VGA and HDMI native resolutions will be maintained between both source connections.
The VS221VGA2HD ensures hassle-free operation with two different auto switching modes: automatic switching that detects and selects a newly connected device, as well as priority selection which lets you choose which port should be activated by default for automatic switching.
This A/V switch has been designed with the boardroom and classroom in mind: the VS221VGA2HD features VGA and HDMI inputs to support a wide range of devices, and the built-in converter makes it easy to connect to the room's display without the use of additional adapters. Plus, automatic switching encourages on-the-fly collaboration among students or co-workers, by making it easy to share your projector between multiple source devices.
If you are looking for a similar device with VGA output, please see the VS221HD2VGA.
StarTech.com 2x1 VGA + HDMI to HDMI Switch / Selector Box - 1080p Multi Video Input Automatic Switcher - 2 Computers In 1 Monitor Out (VS221VGA2HD) - video/audio switch
Video/audio switch
Subtype
HDMI
Video/audio switch
Enclosure Type
Desktop
Subtype
HDMI
1 x VGA input HD-15 , 1 x HDMI input , 1 x HDMI output
External power adapter
Mounting brackets
FCC, RoHS
B458 StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.74
B458 StarTech.com 6 ft Monitor VGA Cable - HD15 M/M In Stock £4.11
B458 StarTech.com 4 Port VGA Video Audio Switch with RS232 control In Stock £130.55
B458 StarTech.com 15 ft Monitor VGA Cable - HD15 MM In Stock £5.07
B458 StarTech.com 4-to-1 HDMI Video Switch with Remote Control In Stock £46.75
B458 StarTech.com 2 Port VGA Auto Switch In Stock £39.56
B458 StarTech.com 1 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £4.72
B458 StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £9.57
B458 StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.14
B458 StarTech.com Multiple Video Input with Audio to HDMI Scaler Switcher - HDMI / VGA / Component In Stock £323.13
B458 StarTech.com 2-Port VGA Auto Switch Box with Priority Switching and EDID Copy In Stock £52.01
B458 StarTech.com 2x1 VGA + HDMI to VGA Converter Switch w/ Priority Switching – 1080p In Stock £129.60
B458 StarTech.com 2x1 HDMI VGA to HDMI Converter In Stock £128.11
Price Range Ex VAT: 100 - 150
