StarTech.com 2x USB Wall Charger 17W / 3.4A
Quicklinx: B7JJWS00 Mfr#: USB2PACWH
Type: Rechargeable
Colours:
37 In Stock
£17.39 ex VAT
£20.86 inc VAT
Charge your tablet and your phone simultaneously, almost anywhere around the world. Planning an international business trip or vacation? Now you can keep your mobile devices charged while you're away, without having to worry about whether or not the adapter you use at home will work overseas. The versatile travel charger ships with interchangeable power plugs that let you plug in and charge your devices nearly anywhere you go around the world.
Plus, you can charge two of your devices at the same time. This dual-port USB wall charger lets you charge two mobile devices at once, using a single USB wall charger, so you won't have to wait until one of your devices is fully charged before charging another.
The wall charger includes a universal power adapter, which lets you plug in to any electrical socket almost anywhere in the world. So, no matter where you are traveling to, you can rest assured that you'll be able to keep your mobile devices charged and ready to use.
With one 1A port for charging your smartphone or iPhone, and a 2.4A port for charging your iPad or other tablet, you'll always have the necessary charging power for your mobile devices. Whether you're charging two phones at the same time or charging a phone and a tablet, you can ensure all of your mobile devices are ready when you need them.
The portable USB wall charger features a folding North American plug that tucks away nicely to fit inside your laptop bag, purse, backpack or other carrying case, making it the perfect mobile accessory for any carry-on. Plus, you can easily throw in the correct international plug for your destination and you're all set to go.
Once you land you can swap out the plugs and be ready to charge in the airport, in your hotel room or just about anywhere you can find a wall outlet.
Some mobile devices such as certain Samsung and BlackBerry devices use proprietary power connections which are not compatible with aftermarket chargers. Please consult the manufacturer's documentation to ensure compatibility with the USB2PACWH.
  • Efficient charging capabilities
    This power adapter provides a maximum electric current of 3.4 A, ensuring fast and effective charging for your devices. With an output of 17 W, it is suitable for powering up tablets and smartphones quickly.
  • Dual USB ports for convenience
    Featuring two 4-pin USB Type-A ports, this charger enables the simultaneous charging of multiple devices, reducing the need for multiple adapters and enhancing user convenience.
  • Safety certified
    The charger meets several compliance standards, including UL, GS, RoHS, PSE Mark, and RCM, which ensures that it adheres to safety and environmental regulations during use.
  • Compact and travel-friendly
    With a lightweight design, this wall charger is perfect for travelers. It operates efficiently across different voltages, specifically 110 V and 220 V, making it versatile for use in various countries.
StarTech.com Dual Port USB Wall Charger 17W/3.4A - Travel Charger 110V/220V power adapter - USB - 17 Watt
Power adapter
Tablet, mobile phone
132 g
White
Output Connector Type
Total 2: USB
AC 100-240 V
Voltage Provided
5 V
Max Electric Current
3.4 A
Power Provided
17 Watt
Power Device Details
- 4 pin USB Type A - 1 A , - 4 pin USB Type A - 2.4 A
P/N: USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA, VID2VGATV3
Power adapter
132 g
Enclosure Colour
White
AC 100-240 V
Voltage Provided
5 V
Output connectors
Total 2: 4 pin USB Type A
Power Provided
17 Watt
3.4 A
4 pin USB Type A - 1 A , 4 pin USB Type A - 2.4 A
Power plug adapter (EU), power plug adapter (UK), power plug adapter (AU), power plug adapter (US)
UL, GS, RoHS, PSE Mark, RCM
B7JJ StarTech.com 3m (10ft) Long Black Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £18.04
B7JJ StarTech.com 3m (10ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £17.97
B7JJ StarTech.com 2m Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets In Stock £5.47
B7JJ StarTech.com USB Wall Charger 17W / 3.4A x2 In Stock £13.05
B7JJ StarTech.com 2x USB Wall Charger 17W / 3.4A In Stock £17.39
B7JJ StarTech.com 10-Pt USB 3.0 Hub w/ Charging In Stock £64.21
B7JJ StarTech.com 7-Pt USB 3.0 Hub + Charge Pts In Stock £56.18
B7JJ StarTech.com 140W USB-C Wall Charger, GaN In Stock £70.94
B7JJ StarTech.com 4-Port USB-C Charger, 240W In Stock £140.51
Type: Rechargeable
