StarTech.com USB Wall Charger 17W / 3.4A x2
Quicklinx: B2WFWS00 Mfr#: USB2PACBK
Type: Rechargeable
Colours:
42 In Stock
£13.05 ex VAT
£15.66 inc VAT
Charge your tablet and your phone simultaneously. Planning an international business trip or vacation? Now you can keep your mobile devices charged while you're away, without having to worry about whether or not the adapter you use at home will work overseas. The versatile travel charger ships with interchangeable power plugs that let you plug in and charge your devices nearly anywhere you go around the world.
Plus, you can charge two of your devices at the same time. This dual-port USB wall charger lets you charge two mobile devices at once, using a single USB wall charger, so you won't have to wait until one of your devices is fully charged before charging another.
The wall charger includes a universal power adapter, which lets you plug in to any electrical socket almost anywhere in the world. So, no matter where you are traveling to, you can rest assured that you'll be able to keep your mobile devices charged and ready to use.
With one 1A port for charging your smartphone or iPhone, and a 2.4A port for charging your iPad or other tablet, you'll always have the necessary charging power for your mobile devices. Whether you're charging two phones at the same time or charging a phone and a tablet, you can ensure all of your mobile devices are ready when you need them.
The portable USB wall charger features a folding North American plug that tucks away nicely to fit inside your laptop bag, purse, backpack or other carrying case, making it the perfect mobile accessory for any carry-on. Plus, you can easily throw in the correct international plug for your destination and you're all set to go.
Once you land you can swap out the plugs and be ready to charge in the airport, in your hotel room or just about anywhere you can find a wall outlet.
Some mobile devices such as certain Samsung and BlackBerry devices use proprietary power connections which are not compatible with aftermarket chargers. Please consult the manufacturer's documentation to ensure compatibility with the USB2PACBK.
  • Efficient charging capabilities
    This power adapter features a maximum electric current of 3.4 A, allowing quick charging for multiple devices. The two USB ports enable simultaneous charging, increasing efficiency during travel.
  • Broad compatibility
    Designed to work with various devices, the charger supports tablets and cellular phones, making it a versatile choice for different users and scenarios.
  • Strict safety compliance
    The charger adheres to important safety standards including UL, GS, RoHS, PSE Mark, and RCM. This ensures that users can charge their devices safely and with confidence.
StarTech.com Travel USB Wall Charger - 2 Port - Black - Universal Travel Adapter - International Power Adapter - USB Charger (USB2PACBK) power adapter - USB - 17 Watt
Power adapter
Tablet, mobile phone
132 g
Output Connector Type
Total 2: USB
AC 100-240 V
Voltage Provided
5 V
Max Electric Current
3.4 A
Power Provided
17 Watt
Power Device Details
- 4 pin USB Type A - 1 A , - 4 pin USB Type A - 2.4 A
P/N: USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA, VID2VGATV3
Power adapter
132 g
Enclosure Colour
AC 100-240 V
Voltage Provided
5 V
Output connectors
Total 2: 4 pin USB Type A
Power Provided
17 Watt
3.4 A
4 pin USB Type A - 1 A , 4 pin USB Type A - 2.4 A
Power plug adapter (EU), power plug adapter (UK), power plug adapter (AU), power plug adapter (US)
UL, GS, RoHS, PSE Mark, RCM
B2WF StarTech.com 3m (10ft) Long Black Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £18.04
B2WF StarTech.com 3m (10ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £17.97
B2WF StarTech.com 2m Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets In Stock £5.47
B2WF StarTech.com USB Wall Charger 17W / 3.4A x2 In Stock £13.05
B2WF StarTech.com 10-Pt USB 3.0 Hub w/ Charging In Stock £64.21
B2WF StarTech.com 7-Pt USB 3.0 Hub + Charge Pts In Stock £56.18
B2WF StarTech.com 140W USB-C Wall Charger, GaN In Stock £70.94
B2WF StarTech.com 4-Port USB-C Charger, 240W In Stock £140.51
Type: Rechargeable
