Charge your tablet and your phone simultaneously, almost anywhere around the world. Planning an international business trip or vacation? Now you can keep your mobile devices charged while you're away, without having to worry about whether or not the adapter you use at home will work overseas. The versatile travel charger ships with interchangeable power plugs that let you plug in and charge your devices nearly anywhere you go around the world.
Plus, you can charge two of your devices at the same time. This dual-port USB wall charger lets you charge two mobile devices at once, using a single USB wall charger, so you won't have to wait until one of your devices is fully charged before charging another.
The wall charger includes a universal power adapter, which lets you plug in to any electrical socket almost anywhere in the world. So, no matter where you are traveling to, you can rest assured that you'll be able to keep your mobile devices charged and ready to use.
With one 1A port for charging your smartphone or iPhone, and a 2.4A port for charging your iPad or other tablet, you'll always have the necessary charging power for your mobile devices. Whether you're charging two phones at the same time or charging a phone and a tablet, you can ensure all of your mobile devices are ready when you need them.
The portable USB wall charger features a folding North American plug that tucks away nicely to fit inside your laptop bag, purse, backpack or other carrying case, making it the perfect mobile accessory for any carry-on. Plus, you can easily throw in the correct international plug for your destination and you're all set to go.
Once you land you can swap out the plugs and be ready to charge in the airport, in your hotel room or just about anywhere you can find a wall outlet.
Some mobile devices such as certain Samsung and BlackBerry devices use proprietary power connections which are not compatible with aftermarket chargers. Please consult the manufacturer's documentation to ensure compatibility with the USB2PACWH.
- StarTech.com Dual Port USB Wall Charger 17W/3.4A - Travel Charger 110V/220V power adapter - USB - 17 Watt
- Product Type
- Power adapter
- Designed For
- Tablet, mobile phone
- 132 g
- White
- Output Connector Type
- Total 2: USB
- Voltage Required
- AC 100-240 V
- Voltage Provided
- 5 V
- Max Electric Current
- 3.4 A
- Power Provided
- 17 Watt
- Power Device Details
- - 4 pin USB Type A - 1 A , - 4 pin USB Type A - 2.4 A
- 2-year warranty
- Designed For
- P/N: USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA, VID2VGATV3
- Product Type
- Power adapter
- Designed For
- 132 g
- Enclosure Colour
- White
- Voltage Required
- AC 100-240 V
- Voltage Provided
- 5 V
- Output connectors
- Total 2: 4 pin USB Type A
- Power Provided
- 17 Watt
- 3.4 A
- 4 pin USB Type A - 1 A , 4 pin USB Type A - 2.4 A
- Included Accessories
- Power plug adapter (EU), power plug adapter (UK), power plug adapter (AU), power plug adapter (US)
- UL, GS, RoHS, PSE Mark, RCM
- Limited warranty - 2 years
- Designed For
StarTech.com 3m (10ft) Long Black Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad | In Stock | £21.34 |
StarTech.com 3m (10ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad | In Stock | £21.34 |
StarTech.com 2m Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets | In Stock | £5.47 |
StarTech.com USB Wall Charger 17W / 3.4A x2 | In Stock | £15.26 |
StarTech.com 2x USB Wall Charger 17W / 3.4A | In Stock | £15.41 |
StarTech.com 10-Pt USB 3.0 Hub w/ Charging | In Stock | £66.08 |
StarTech.com 4-Port USB 3 Hub + 2.4A DCP | In Stock | £43.24 |
StarTech.com 7-Pt USB 3.0 Hub + Charge Pts | In Stock | £60.12 |
StarTech.com 140W USB-C Wall Charger, GaN | In Stock | £68.14 |
StarTech.com 4-Port USB-C Charger, 240W | In Stock | £150.05 |
