StarTech.com 2S2P PCI Serial Parallel Combo Card with 16C1050 UART
Quicklinx: 84NSWS00 Mfr#: PCI2S2PMC
Add two Serial and two Parallel ports to your desktop system through a single PCI slot. The PCI2S2PMC 2S2P PCI Serial/Parallel Combo Card (16C1050 UART) adds 2 RS232 serial, and 2 IEEE-1284 Parallel ports to your system, through a PCI slot. Supporting RS232 speeds up to 115.2 Kbps and parallel rates up to 1.5 Mbps, the serial/parallel adapter offers the added connectivity needed for industrial and business applications, while only occupying a single 3.3/5V PCI slot. This 2S-2P card offers a broad operating system compatibility list that includes Windows? 7, Windows Server 2003, XP, DOS? and Linux, for simple integration into mixed environments.
StarTech.com 2S2P PCI Serial Parallel Combo Card with 16C1050 UART - parallel/serial adapter - PCI
Parallel/serial adapter
Plug-in card
Interface (Bus) Type
PCI
1.9 cm x 13.3 cm x 8.9 cm
200 g
Parallel, serial
Microsoft DOS, Microsoft Windows 2000 / NT4.0, Microsoft Windows XP, Microsoft Windows 7, Linux 2.6.x, Microsoft Windows Vista, Windows 10 (32/64 bits)
Plug-in card
PCI
Wired
Parallel, serial
2 - 25 pin D-Sub (DB-25) , 2 x serial - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI
FCC, RoHS
Software Included
Drivers & Utilities
1.9 cm
13.3 cm
8.9 cm
200 g
Limited warranty - lifetime
85 °C
84NS StarTech.com 6 ft RJ45 to DB9 Cisco Console Management Router Cable - M/F In Stock £21.71
84NS StarTech.com DB9 RS232 Serial Null Modem Adapter - M/F In Stock £5.24
84NS StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.43
