This 2S2I PCI Express SATA/IDE Combo Controller Adapter Card lets you add two Serial ATA (SATA) and two IDE channels (2 IDE drives per channel) to a computer, through a single PCIe slot. The SATA/IDE combo adapter card offers a hardware RAID solution with support for RAID 0, RAID 1 and JBOD, allowing you to configure your SATA drives to meet individual storage needs.
- StarTech.com 2S2I PCI Express SATA IDE Combo Controller Adapter Card - storage controller (RAID) - ATA-133 / SATA 3Gb/s / eSATA 3Gb/s - PCIe x1
- Storage controller (RAID) - plug-in card
- Bus Type
- PCIe x1
- Interface
- Data Transfer Rate
- 3 Gbit/s
- Supported Devices
- Disk array (RAID)
- RAID Level
- RAID 0, RAID 1, JBOD
- System Requirements
- Microsoft Windows Vista / 2000 / XP
- Limited lifetime warranty
- Host Bus
- PCIe x1
Storage Controller
- Interface
- 3 Gbit/s
- Supported Devices
- Disk array (RAID)
- RAID Level
- 2 x ATA-133 - 40 PIN IDC (internal) , 1 x SATA 3Gb/s - SATA (internal) , 1 x eSATA 3Gb/s - eSATA (external)
- Compatible Slots
- 1 x PCI Express x1
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - lifetime
