The StarTech.com 2P Serial to Ethernet Adapter is a comprehensive connectivity solution, designed to bridge the gap between RS232 DB9 devices and IP-based Ethernet networks. This adapter facilitates the seamless integration of serial devices with modern TCP/IP networks, making it an essential tool for industries relying on serial communication. It features a robust metal housing, ensuring durability and reliability in demanding industrial environments. With support for both Fast Ethernet and RS-232 data link protocols, this device server offers high-speed data transfer rates of up to 921.6 Kbps, alongside advanced features such as electrostatic discharge protection, adjustable parity, and flow control. Its compatibility with IEEE 802.3i and 802.3u standards, along with a wide operating temperature and humidity range, makes it a versatile solution for a variety of networking challenges. Furthermore, the adapter's capability for wall or DIN rail mounting provides flexibility in installation, ensuring it can be deployed in the most effective manner for any given scenario.
Robust connectivity
Equipped with dual RS-232 DB-9 connectors and a single RJ-45, this adapter ensures versatile connectivity options for a wide range of devices. -
Enhanced durability
The metal housing and electrostatic discharge protection up to 15 kV provide a durable solution for industrial environments. -
Efficient management
Features such as auto-negotiation, flow control, and full duplex capability ensure smooth and manageable network communication. -
Flexible installation
Designed for wall or DIN rail mounting, this device server can be installed in various settings, making it a versatile choice for network infrastructure.
- StarTech.com 2P Serial to Ethernet Adapter, IP LAN to RS232 DB9 Converter - device server - TAA Compliant
- Device server
- Form Factor
- Wall / DIN rail mountable
- Ports Qty
- 2
- Data Link Protocol
- Ethernet, Fast Ethernet, RS-232
- Included Accessories
- DIN-rail mounting kit, wall mounting kit
- OS Required
- Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11
- Power
- AC 100-240 V
- TAA Compliant
- 6 cm x 17.9 cm x 2.3 cm
- 315 g
- 2-year warranty
- Device server
- 6 cm
- 17.9 cm
- 2.3 cm
- 315 g
- Enclosure Colour
- Black
- Form Factor
- Ports Qty
- 2
- Connectivity Technology
- Wired
- Data Transfer Rate
- 921.6 Kbps
- Telnet, UDP, TCP
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- Telnet, UDP
- Status Indicators
- Power, transmit, receive, link/activity
- Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), manageable, 15 KV Electrostatic Discharge Protection, metal housing, 8 KV Contact Electrostatic Discharge Protection, adjustable parity
- IEEE 802.3u, IEEE 802.3i
- 2 x RS-232 - DB-9 , 1 x 100Base-TX - RJ-45 , 1 x - terminal block
- EIA/TIA-232
- TAA Compliant
- Power Device
- External power adapter
- Voltage Required
- AC 100-240 V
- 15 Watt
- OS Required
- Shipping Width
- 16.6 cm
- Shipping Depth
- 24.2 cm
- Shipping Height
- 5.5 cm
- Shipping Weight
- 600 g
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 5 - 95% RH (non-condensing)
StarTech.com Slimline DB9 Serial Gender Changer - F/F | In Stock | £4.70 |
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.58 |
StarTech.com Serial to Ethernet Adapter | In Stock | £120.64 |
StarTech.com 4P Serial to Ethernet Adapter | In Stock | £321.80 |
