This Slimline DB9 Gender Changer features two slimline DB9F connectors, offering a reliable, cost-saving way to convert a 9 pin male port to a 9 pin female port. The Slimline DB9 Gender Changer guarantees long-lasting performance.
Seamless connectivity
The Slimline DB9 Serial Gender Changer by StarTech.com offers a straightforward solution for connecting two male serial devices. This gender changer ensures a reliable connection between PC peripherals, enhancing your setup's efficiency. -
Durable design
Crafted for longevity, this serial gender changer features a robust construction that can withstand the rigors of daily use. Its compact size makes it an unobtrusive addition to any workstation. -
Lifetime warranty
StarTech.com stands behind their product with a lifetime limited warranty, providing peace of mind and assurance of quality.
 - StarTech.com Slimline DB9 Serial Gender Changer - F/F - Serial gender changer - DB-9 (F) to DB-9 (F) - GC9SF - serial gender converter - DB-9 to DB-9
 - Serial gender converter
- Connector
 - 9 pin D-Sub (DB-9) - female
- Connector (Second End)
 - Limited lifetime warranty
- Designed For
 - P/N: ICUSB2324852, ICUSB422, ICUSB422IS, NETRS232, NETRS2321P, NETRS2321POE, NETRS2322P, NETRS232485W
- Connector
- Designed For
                        StarTech.com 4P Serial to Ethernet Adapter | In Stock | £305.29 |
