StarTech.com 2P Serial to Ethernet Adapter
Quicklinx: HVMFWS00 Mfr#: I23-SERIAL-ETHERNET
Hurry, only 2 left in stock!
£185.00 ex VAT
£222.00 inc VAT
The StarTech.com 2P Serial to Ethernet Adapter is a comprehensive connectivity solution, designed to bridge the gap between RS232 DB9 devices and IP-based Ethernet networks. This adapter facilitates the seamless integration of serial devices with modern TCP/IP networks, making it an essential tool for industries relying on serial communication. It features a robust metal housing, ensuring durability and reliability in demanding industrial environments. With support for both Fast Ethernet and RS-232 data link protocols, this device server offers high-speed data transfer rates of up to 921.6 Kbps, alongside advanced features such as electrostatic discharge protection, adjustable parity, and flow control. Its compatibility with IEEE 802.3i and 802.3u standards, along with a wide operating temperature and humidity range, makes it a versatile solution for a variety of networking challenges. Furthermore, the adapter's capability for wall or DIN rail mounting provides flexibility in installation, ensuring it can be deployed in the most effective manner for any given scenario.
  • Robust connectivity
    Equipped with dual RS-232 DB-9 connectors and a single RJ-45, this adapter ensures versatile connectivity options for a wide range of devices.
  • Enhanced durability
    The metal housing and electrostatic discharge protection up to 15 kV provide a durable solution for industrial environments.
  • Efficient management
    Features such as auto-negotiation, flow control, and full duplex capability ensure smooth and manageable network communication.
  • Flexible installation
    Designed for wall or DIN rail mounting, this device server can be installed in various settings, making it a versatile choice for network infrastructure.
StarTech.com 2P Serial to Ethernet Adapter, IP LAN to RS232 DB9 Converter - device server - TAA Compliant
Device server
Wall / DIN rail mountable
Ports Qty
2
Ethernet, Fast Ethernet, RS-232
DIN-rail mounting kit, wall mounting kit
Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11
AC 100-240 V
TAA Compliant
6 cm x 17.9 cm x 2.3 cm
315 g
Device server
6 cm
17.9 cm
2.3 cm
315 g
Enclosure Colour
Ports Qty
2
Wired
Data Transfer Rate
921.6 Kbps
Network / Transport Protocol
Telnet, UDP, TCP
Routing Protocol
Static IP routing
Remote Management Protocol
Telnet, UDP
Status Indicators
Power, transmit, receive, link/activity
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), manageable, 15 KV Electrostatic Discharge Protection, metal housing, 8 KV Contact Electrostatic Discharge Protection, adjustable parity
IEEE 802.3u, IEEE 802.3i
2 x RS-232 - DB-9 , 1 x 100Base-TX - RJ-45 , 1 x - terminal block
EIA/TIA-232
TAA Compliant
External power adapter
AC 100-240 V
15 Watt
Shipping Width
16.6 cm
Shipping Depth
24.2 cm
Shipping Height
5.5 cm
Shipping Weight
600 g
60 °C
5 - 95% RH (non-condensing)
HVMF StarTech.com Slimline DB9 Serial Gender Changer - F/F In Stock £4.64
HVMF StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.58
HVMF StarTech.com Serial to Ethernet Adapter In Stock £120.64
HVMF StarTech.com PoE Serial to Ethernet Adapter In Stock £160.87
HVMF StarTech.com 4P Serial to Ethernet Adapter In Stock £321.80
