StarTech.com 2m USB-C to DVI Cable
Quicklinx: CFQLWS00 Mfr#: CDP2DVIMM2MB
16 in stock
£24.08 ex VAT
£28.89 inc VAT
Eliminate clutter by connecting your USB Type-C computer directly to a DVI display, without additional adapters. This USB-C to DVI adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your DVI-I monitor, television or projector.
The adapter supports a connection distance of up to 2 m (6 ft.) and works with USB-C devices that support DP alt mode, such as the MacBook, ChromeBook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 2 m (6 ft.) in length, the adapter cable delivers a direct connection between your USB-C device and your DVI monitor. This means you don't have to use additional adapters or cabling, which helps ensure a tidy and professional installation. For shorter installations, a 1 m (3 ft.) USB-C to DVI cable enable you to choose the right cable length for your custom installation needs.
The USB-C to DVI adapter cable is easy to connect, through the versatility and convenience of the USB Type-C port on your device. USB-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always connect. This saves you the frustration of trying to insert it correctly when you're docking your computer to your workstation or office hot desk.
The adapter harnesses the video capabilities that are built into your USB Type-C connector to deliver video resolutions up to 2560x1600, providing full dual-link support for your high-resolution DVI monitors - great for multitasking on high-resolution DVI displays. The adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other HD work environments.
Your USB-C equipped device must support video (DP alt mode) to work with this adapter.
  • Clutter-free installation
  • Hassle-free connection with USB Type-C
  • Crystal-clear picture quality
StarTech.com 6.6 ft / 2 m USB-C to DVI Cable - 1920 x 1200 - Black - external video adapter
External video adapter
Bus Type
USB-C
Max Resolution
2560 x 1600
DVI-D (male connector)
3-year warranty
Bus Type
USB-C
Max Resolution
2560 x 1600
- 2 m
FCC, RoHS, WEEE
Limited warranty - 3 years
70 °C
5 - 90% (non-condensing)
CFQL StarTech.com USB-C to HDMI Adapter In Stock £17.77
CFQL StarTech.com USB-C to DVI Adapter In Stock £20.24
CFQL StarTech.com USB-C to DVI Adapter - White In Stock £20.24
CFQL StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £26.93
CFQL StarTech.com 2m USB-C to DVI Cable In Stock £24.08
CFQL StarTech.com 2m USB-C to HDMI Cable In Stock £24.08
CFQL StarTech.com 1m USB-C to HDMI Cable In Stock £22.13
Price Range Ex VAT: 0 - 50
