StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female
Quicklinx: 8FHWWS00 Mfr#: HDDVIMF8IN
Length: 20.32cm
39 In Stock
£9.71 ex VAT
£11.65 inc VAT
Connect a DVI-D device to an HDMI-enabled device using a standard HDMI cable. The HDDVIMF8IN HDMI to DVI Cable Adapter features one HDMI male connector and one DVI-D female connector, which enables a bi-directional connection between HDMI-capable devices and DVI-D capable devices to overcome compatibility issues.
The HDMI to DVI dongle offers 8-inches in cable length, which lessens strain on the connectors and prevents damage to the cable, while also reducing the potential of blocking other nearby ports.
  • Robust shielding
    This cable boasts shielded technology featuring aluminum mylar foil with braid, effectively reducing signal interference and ensuring stable video transmission.
  • High-quality connectors
    Equipped with gold-plated connectors, this adapter provides enhanced conductivity and resistivity against corrosion, improving durability over time.
StarTech.com HDMI Male to DVI Female Adapter - 8in - 1080p DVI-D Gender Changer Cable (HDDVIMF8IN) - adapter - HDMI / DVI - 20.32 cm
Cable
Adapter - HDMI / DVI
Shielded
American Wire Gauge (AWG)
28
Length
20.32 cm
Connector
HDMI - male
Connector (Second End)
DVI-D - female
P/N: 45PATCH25WH, BNDDKT30CAHV, CDP2DVIMM2MB, DKT30CSDHPD, DKT30CSDHPD3, DP2DVI2MM3, DP2DVI2MM6, DP2DVIMM10, DP2DVIMM6, DP2DVIMM6BS, DP2DVIMM6X10, DVIDSMM10, DVIMM6, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, USB31GEHD, USB3SMDOCKHV
Cable Type
Adapter
Interface Supported
HDMI / DVI
Shielded
28
Jacket Material
PVC
Shielding Material
Length
20.32 cm
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
24+1 pin digital DVI - female
RoHS
Limited warranty - lifetime
8FHW StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.80
8FHW StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.48
8FHW StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Female to DVI Male In Stock £9.26
8FHW StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £9.71
8FHW StarTech.com DVI-D to VGA Active Adapter Converter Cable – 1920x1200 In Stock £22.98
Length: 20.32cm
