Eliminate clutter by connecting your USB Type-C computer directly to a DVI display, without additional adapters. This USB-C to DVI adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your DVI-I monitor, television or projector.
The adapter supports a connection distance of up to 2 m (6 ft.) and works with USB-C devices that support DP alt mode, such as the MacBook, ChromeBook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 2 m (6 ft.) in length, the adapter cable delivers a direct connection between your USB-C device and your DVI monitor. This means you don't have to use additional adapters or cabling, which helps ensure a tidy and professional installation. For shorter installations, a 1 m (3 ft.) USB-C to DVI cable enable you to choose the right cable length for your custom installation needs.
The USB-C to DVI adapter cable is easy to connect, through the versatility and convenience of the USB Type-C port on your device. USB-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always connect. This saves you the frustration of trying to insert it correctly when you're docking your computer to your workstation or office hot desk.
The adapter harnesses the video capabilities that are built into your USB Type-C connector to deliver video resolutions up to 2560x1600, providing full dual-link support for your high-resolution DVI monitors - great for multitasking on high-resolution DVI displays. The adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other HD work environments.
Your USB-C equipped device must support video (DP alt mode) to work with this adapter.
Clutter-free installation
At 2 m (6 ft.) in length, the adapter cable delivers a direct connection between your USB-C device and your DVI monitor. This means you don't have to use additional adapters or cabling, which helps ensure a tidy and professional installation. -
Hassle-free connection with USB Type-C
The USB-C to DVI adapter cable is easy to connect, through the versatility and convenience of the USB Type-C port on your device. USB-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always connect. This saves you the frustration of trying to insert it correctly when you're docking your computer to your workstation or office hot desk. -
Crystal-clear picture quality
- StarTech.com USB-C to DVI Cable - 6 ft / 2m - 1080p - 1920x1200 - USB-C DVI Monitor Cable - USB C Cable - Computer Monitor Cable (CDP2DVIMM2MB) - USB / DVI cable - 24 pin USB-C to DVI-D - 2 m
- USB / DVI cable
- 1920 x 1200 (WUXGA) support, DisplayPort Alternate Mode support
- Length
- 2 m
- Connector
- 24 pin USB-C - male (input)
- Connector (Second End)
- 24+1 pin digital DVI - male (output)
- Thunderbolt 3 / USB 3.1
- Black
- 3-year warranty
- Designed For
- P/N: TB4CDOCK
- USB / DVI cable
- Length
- 2 m
- Black
- 147 g
- Connector
- Thunderbolt 3 / USB 3.1, FCC, RoHS
- Shipping Width
- 12.5 cm
- Shipping Depth
- 22.5 cm
- Shipping Height
- 2.6 cm
- Shipping Weight
- 152 g
- 3-year warranty
- Designed For
- P/N: TB4CDOCK
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £9.83 |
StarTech.com 6in DVI-D Dual Link Digital Port Saver Extension Cable M/F | In Stock | £9.57 |
StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female | In Stock | £10.14 |
StarTech.com USB-C to VGA Adapter - White | In Stock | £21.91 |
StarTech.com USB-C to HDMI Adapter | In Stock | £16.83 |
StarTech.com USB-C to HDMI Adapter | In Stock | £18.72 |
StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz | In Stock | £32.07 |
StarTech.com 2m USB-C to DVI Cable | In Stock | £24.20 |
StarTech.com 2m USB-C to HDMI Cable | In Stock | £31.42 |
StarTech.com USB-C to VGA - Power Delivery | In Stock | £23.45 |
StarTech.com 1m USB-C to DVI Cable | In Stock | £22.22 |
StarTech.com 1m USB-C to HDMI Cable | In Stock | £27.78 |
StarTech.com 1m USB-C to VGA Cable | In Stock | £19.94 |
StarTech.com 2m USB-C to VGA Cable | In Stock | £21.00 |
StarTech.com USB-C to HDMI - Power Delivery | In Stock | £25.54 |
StarTech.com 2m USB C to HDMI Cable - Black | In Stock | £29.47 |
StarTech.com 1m USB C to HDMI Cable - Black | In Stock | £27.67 |
StarTech.com 3m USB C to HDMI Cable - Black | In Stock | £28.92 |
StarTech.com 1m USB C to HDMI Cable - White | In Stock | £24.33 |
