StarTech.com 2m Thunderbolt 3 20Gbps Cable
Quicklinx: BVV1WS00 Mfr#: TBLT3MM2M
Length: 2m
29 In Stock
£40.57 ex VAT
£48.68 inc VAT
Provide twice the data transfer speed of any other cable type, enable full 4K 60Hz video, and power your devices with a single cable. This Thunderbolt 3 (20Gbps) cable lets you connect to any Thunderbolt 3 port (USB-C) to deliver video and data to your Thunderbolt, USB, and DisplayPort devices. Plus, the cable can provide power for charging your devices, and you can link up to six Thunderbolt 3 devices as part of a daisy-chained connection.
This cable supports data transfer rates of 20Gbps when connected to a Thunderbolt 3 device, so you can transfer photo and video files at twice the speed of a USB 3.1 Gen 2 (10Gbps) cable. For example, you can transfer a 4K movie in less than a minute. When connected to a USB 3.1 device, the cable supports data transfer rates of 10Gbps.
The cable supports full 4K 60Hz video and DisplayPort 1.2, and is compatible with existing DisplayPort displays. It's perfect for connecting your docking station or laptop to a monitor with astonishing resolution, contrast, and color depth for amazing detail.
This Thunderbolt 3 cable delivers up to 60W of power for charging a laptop or powering a display, and 15W for bus-powered devices such as a hard drive enclosure.
The cable gives you an easy way to bridge multiple Thunderbolt 3 enabled laptops for peer-to-peer 10GbE networking. It's perfect for setting up small workgroups and sharing peripherals such as printers and storage. You can also connect two Thunderbolt 3 laptops together for PC migrations.
This Thunderbolt 3 cable can also be used as a USB cable for your USB 3.0 and 3.1 devices, with data transfer speeds of up to 5Gbps. And while regular USB 3.0 and 3.1 USB-C cables allow for a maximum connection of up to 1m, this cable allows for a connection distance of up to 2m.
  • Faster data transfers when connected to Thunderbolt devices
  • USB-C compatible
    The Thunderbolt 3 cable is fully compatible with all of your USB 3.1 (5Gbps) devices and can be used for charging and syncing your mobile devices. You can also connect and power USB-C laptops, such as your MacBook or Chromebook , and USB-C peripherals, such as your portable hard drive and docking station.
  • Full 4K video
  • Versatile power delivery
    This Thunderbolt 3 cable delivers up to 100W of power for charging a laptop or powering a display, and 15W for bus-powered devices such as a hard drive enclosure.
  • Thunderbolt networking
    The cable gives you an easy way to bridge multiple Thunderbolt 3 enabled laptops for peer-to-peer 10GbE networking. It's perfect for setting up small workgroups and sharing peripherals such as printers and storage. You can also connect two Thunderbolt 3 laptops together for PC migrations. The TBLT3MM2M is backed by a 2-year warranty.
StarTech.com 2m (6.6ft) Thunderbolt 3 Cable, 20Gbps, 100W PD, 4K Video, Thunderbolt-Certified, Compatible w/ TB4/USB 3.2/DisplayPort - Thunderbolt cable - 24 pin USB-C to 24 pin USB-C - 2 m
Thunderbolt cable
Double shielded
Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Thunderbolt 3 / USB / DisplayPort
P/N: CDP2HDUACP, CDP2HDUACPW, MST30C2DPPD
Thunderbolt cable
Double shielded
Jacket Material
PVC
Plated Connector
Nickel
Length
2 m
84 g
Connector
24 pin USB-C - male
24 pin USB-C - male
BVV1 StarTech.com 2m Thunderbolt 3 20Gbps Cable In Stock £40.57
BVV1 StarTech.com 1m Thunderbolt 3 20Gbps Cable In Stock £33.89
BVV1 StarTech.com 0.5m Thunderbolt 3 Cable In Stock £29.76
BVV1 StarTech.com M.2 SATA Enclosure with USB-C In Stock £25.86
BVV1 StarTech.com Hard Disk Drive Duplicator Dock In Stock £80.20
BVV1 StarTech.com Dual M.2 Enclosure - RAID In Stock £42.94
BVV1 StarTech.com 0.5m Thunderbolt 3 Cable White In Stock £10.76
BVV1 StarTech.com 1m Thunderbolt 3 Cable White In Stock £33.00
BVV1 StarTech.com 2m Thunderbolt 3 Cable White In Stock £39.59
BVV1 StarTech.com 0.8m / 2.7ft Thunderbolt 3 to Thunderbolt 3 Cable - 40Gbps In Stock £32.51
BVV1 StarTech.com 3ft USB4 Cable, USB-C 40 Gbps In Stock £20.69
BVV1 StarTech.com 6ft (2m) Thunderbolt Cable In Stock £83.57
BVV1 StarTech.com 1m USB4 Cable, USB-C 40 Gbps In Stock £20.51
BVV1 StarTech.com 1.6ft USB4 Cable, USB-C 40Gbps In Stock £19.39
Length: 2m
