Turn your M.2 NGFF SATA drive into an ultra-fast, ultra-portable storage solution for USB-C enabled devices. This compact M.2 SSD enclosure lets you add highly portable data storage to any laptop or computer with a USB-C port - such as MacBook, Chromebook Pixel, Dell XPS laptops, and many others. It turns your SATA M.2 drive into a high-speed storage solution over a USB 3.1 Gen 2 connection, at up to 10Gbps throughput.
This slim, pocket-sized M.2 NGFF SSD enclosure has been specially designed for mobility, with a small form factor design that fits easily into your laptop bag. Its lightweight yet durable aluminum housing helps to ensure your drive won't be damaged while you're on the move.
Ventilation holes help to dissipate heat and help ensure an optimum operating temperature.
Leverage the speed of your M.2 NGFF SATA drive with this external enclosure. It delivers USB 3.1 Gen 2 data transfer speeds up to 10Gbps as well as UASP support, so you can achieve higher transfer speeds when you connect it to a UASP-enabled host computer.
The enclosure works with tablets, laptops and desktop computers and is compatible with hosts equipped with Thunderbolt 3 USB-C ports.
The enclosure is compatible with all of the common M.2 SSDs, and enables you to mount multiple drive lengths, including: 30mm (2230), 42mm (2242), 60mm (2260), and 80mm (2280).
Robust material construction
The enclosure is made from aluminum, providing strength and durability to safeguard your SSD from physical damage. -
Efficient data transfer capabilities
With USB 3.1 Gen 2 technology, the enclosure allows for data transfer rates of up to 10 Gbps, ensuring quick access to files. -
Effective cooling design
Ventilation holes enhance airflow, cooling the drive during operation to maintain optimal performance and longevity. -
Broad compatibility
Designed for Mac users, supporting M.2 SSDs while ensuring seamless integration into existing setups. -
User-friendly setup
The Plug-and-Play functionality ensures easy installation without the need for additional drivers or software.
- StarTech.com M.2 SSD Enclosure for M.2 SATA SSDs - USB 3.1 (10Gbps) with USB-C Cable - External Enclosure for USB-C Host - Aluminum (SM21BMU31C3) - storage enclosure - SATA 6Gb/s - USB 3.1 (Gen 2)
- Storage enclosure - external
- Bus Type
- USB 3.1 (Gen 2)
- Black, silver
- Expansion Bays
- 1 x internal - M.2
- Hard Drive Form Factor Compatibility
- M.2
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Solid state drive
- Max Storage Devices Qty
- 1
- Product Material
- Aluminium
- 8 cm x 1.2 cm x 9.85 cm
- 55 g
- 2-year warranty
- Designed For
- P/N: TBLT3MM1MA, TBLT3MM2M, TBLT3MM2MA
- M.2
- Host Bus
- USB 3.1 (Gen 2)
- Product Material
- Aluminium
- Black, silver
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- Solid state drive
- 1
- Processor
- ASMedia ASM1153
- Bays
- 1 x SATA 6Gb/s - SATA combo
- Connections
- 1 x USB 3.1 (Gen 2) - 24 pin USB-C
- Included Accessories
- Screwdriver, screws
- Cables Included
- 1 x USB cable - external
- USB powered, UASP transfer protocol, ventilation holes
- FCC, RoHS
- Limited warranty - 2 years
- 8 cm
- 1.2 cm
- 9.85 cm
- 55 g
- 0 °C
- 40 °C
- 10 - 90%
- Designed For
StarTech.com USB 3.1 Enclosure for 2.5" SSD | In Stock | £25.78 |
StarTech.com 1m USB 3.1 C to Micro-B Cable | In Stock | £10.07 |
StarTech.com M.2 SATA Enclosure with USB-C | In Stock | £25.64 |
StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter | In Stock | £18.59 |
StarTech.com 3PT M.2 SSD Card - PCIe 3.0 | In Stock | £28.29 |
StarTech.com U.2 2.5" NVMe SSD Adapter | In Stock | £21.67 |
StarTech.com M.2 SATA Raspberry Pi Adapter | In Stock | £19.02 |
StarTech.com Dual M.2 Enclosure - RAID | In Stock | £41.89 |
StarTech.com U.2 to PCIe Adapter -SFF-8639 | In Stock | £31.05 |
StarTech.com 4 Bay SSD/HDD Docking Station | In Stock | £145.83 |
StarTech.com M.2 NVMe SSD Enclosure for PCIe SSDs - USB 3.1 Gen 2 Type-C | In Stock | £44.81 |
StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe | In Stock | £129.01 |
StarTech.com M.2 SSD Enclosure for M.2 SATA Drives - USB 3.1 - USB C M.2 | In Stock | £29.06 |
StarTech.com M.2 NVMe PCIe SSD Enclosure - IP67 water/dust resistance | In Stock | £63.05 |
StarTech.com USB-C 10Gbps to M.2 NVMe or M.2 SATA SSD Enclosure | In Stock | £46.39 |
StarTech.com USB PCIE/SATA M.2 Enclosure | In Stock | £43.99 |
