StarTech.com 2m Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable
Quicklinx: 9KMZWS00 Mfr#: N6PATC2MRD
Length: 2m
Colour: Red
More than 50 In Stock
£4.27 ex VAT
£5.12 inc VAT
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC2MRD Cat 6 Patch Cable (2m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable red PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
Get the highest value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors.
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
  • High performance transmission
    This cable supports tested frequencies of up to 500 MHz, facilitating efficient data transfer and maintaining stability throughout its range.
  • Secure connection design
    Equipped with snagless RJ-45 connectors, this patch cable ensures that connections remain secure and free from damage during installations.
  • Reduced crosstalk interference
    Featuring minimized Near-End Crosstalk (NEXT), this cable enhances signal clarity, allowing for smoother data flow in busy network environments.
  • Durability and flexibility
    Constructed with a durable PVC jacket, this cable is designed to withstand wear and tear while offering flexibility for easy installation.
  • Standard compliance
    This cable adheres to RoHS and ETL compliance, ensuring it meets necessary standards for safety and environmental responsibility.
StarTech.com 2m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Red, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC2MRD) - patch cable - 2 m - red
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Snagless, minimised Near-End Crosstalk (NEXT)
Length
2 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Red
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
2 m
Red
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL - up to 500 MHz
9KMZ StarTech.com 2m White Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £4.42
9KMZ StarTech.com 2m Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £4.42
9KMZ StarTech.com 2m Orange Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £4.42
9KMZ StarTech.com 2m Yellow Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £4.42
9KMZ StarTech.com 2m Green Cat6 Patch Cable In Stock £4.42
9KMZ StarTech.com 2m Purple Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £4.42
9KMZ StarTech.com 2m Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £4.27
Length: 2m
Colour: Red
