StarTech.com 2m Mini USB Cable - A to Down Angle Mini B
Quicklinx: 9073WS00 Mfr#: USBAMB2MD
Length: 2m
Hurry, only 1 left in stock!
£4.21 ex VAT
£5.05 inc VAT
Express delivery Order within the next 22 hours for delivery on Tuesday
Connect your Mini USB devices over longer distances, with the cable out of the way. The USBAMB2MD 2m USB to Down Angle Mini USB Cable provides a high quality connection between your Mini USB 2.0 mobile devices (smartphones, GPS, digital cameras, portable hard drives, etc.) and your PC or Mac computer, for everyday tasks such as charging, data synchronization or file transfers.
The down-angled Mini USB connector allows you to access your Mini USB devices, while keeping the cable out of the way, and stress away from the port.
As an alternative, StarTech.com also offers a 2m USB to Up Angle Mini USB Cable (USBAUB2MU), which provides the same convenience as this down-angled cable, but allows you to connect to your Mini USB device from the opposite direction.
  • Durable construction
    The cable features a molded design that offers enhanced durability, allowing for long-term use.
  • Flexible connectivity
    With a 90° connector type, this cable allows for easier connections in tight spaces.
  • Reliable performance
    This USB cable is double shielded, ensuring excellent data transfer and reducing interference.
  • Corrosion-resistant connectors
    Nickel plating on the connectors helps prevent corrosion, ensuring reliable connection over time.
  • Strain relief design
    The strain relief feature minimizes wear and tear, extending the lifespan of the cable.
StarTech.com Down Angle Mini USB Cable - 2m - Black - USB A to Mini USB B - USB to Mini USB Cable - Mini USB Charger - USB A to Mini B (USBAMB2MD) - USB cable - USB to mini-USB Type B - 2 m
USB cable
Double shielded
90° connector, molded, strain relief
Length
2 m
Connector
4 pin USB Type A - male
Connector (Second End)
Mini-USB Type B - male
USB / USB 2.0
USB cable
Double shielded
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
2 m
Connector
USB / USB 2.0, RoHS
9073 StarTech.com 2m Mini USB Cable - A to Down Angle Mini B In Stock £4.21
9073 StarTech.com 1m Mini USB Cable - A to Up Angle Mini B In Stock £3.59
Length: 2m
