Connect your Mini USB devices, with the cable out of the way. The USBAMB1MU 1m USB to Up Angle Mini USB Cable provides a high quality connection between your Mini USB 2.0 mobile devices (smartphones, GPS, digital cameras, portable hard drives, etc.) and your PC or Mac computer, for everyday tasks such as charging, data synchronization or file transfers.
The up-angled Mini USB connector allows you to access your Mini USB devices, while keeping the cable out of the way, and stress away from the port.
As an alternative, StarTech.com also offers a 1m USB to Down Angle Mini USB Cable (USBAUB1MD), which provides the same convenience as this up-angled cable, but allows you to connect to your Mini USB device from the opposite direction.
Convenient angled design
The 90° connector design helps to easily connect devices in cramped spaces, promoting a tidy setup without bending cables. -
Robust double shielded construction
Featuring double shielding, this cable protects against electromagnetic interference, ensuring a stable and efficient data transfer. -
Durable nickel plated connectors
The connectors are nickel plated, which enhances their resistance to wear and corrosion, thus increasing the cable's lifespan. -
RoHS compliant materials
This cable meets RoHS standards, ensuring that it is produced in an environmentally responsible manner while delivering performance. -
Versatile connectivity
This cable is designed for use with devices requiring a mini-USB Type-B connection, making it a flexible solution for various electronics.
 - StarTech.com 1m Mini USB Cable Cord - A to Up Angle Mini B - Up Angled Mini USB Cable - 1x USB A (M), 1x USB Mini B (M) - Black (USBAMB1MU) - USB cable - USB to mini-USB Type B - 1 m
 - USB cable
- Technology
 - Double shielded
 - 90° connector
- Length
 - 1 m
- Connector
 - 4 pin USB Type A - male
- Connector (Second End)
 - Mini-USB Type B - male
 - Black
 - Limited lifetime warranty
 - USB cable
- Technology
 - Double shielded
- American Wire Gauge (AWG)
 - 28
- Plated Connector
 - Nickel
 - 90° connector
- Length
 - 1 m
 - Black
- Connector
 - RoHS
                        StarTech.com 1m Mini USB Cable - A to Up Angle Mini B | In Stock | £3.92 |
