Provides a high-speed, crystal-clear connection to your DVI digital devices. The DVIDDMM2M 2m DVI-D Dual Link cable features 2 male DVI (25-pin) connectors and provides a reliable, purely digital connection between your desktop or laptop computer and a DVI-D monitor or projector.
The 2m DVI-D digital monitor cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec and is fully compliant with DVI DDWG standards.
Reliable connection
The DVI cable features male connectors on both ends, ensuring a secure connection that minimizes signal loss during video transmission. -
High-resolution support
Ideal for high-definition displays, the cable supports resolutions up to 2560 x 1600, making it suitable for a wide range of applications from gaming to professional presentations. -
Durable construction
Constructed with 28 AWG wire, this cable provides durability and strength to withstand everyday use while maintaining excellent performance. -
Easy compatibility
Designed for devices with a 24+1 pin digital DVI output, this cable offers compatibility with a variety of monitors and computers.
- StarTech.com 2m DVI-D Dual Link Cable - Male to Male DVI-D Digital Video Monitor Cable - 25 pin DVI-D Cable M/M Black 2 Meter - 2560x1600 (DVIDDMM2M) - DVI cable - 2 m
- DVI cable - dual link
- Length
- 2 m
- Connector
- DVI-D - male
- Connector (Second End)
- DVI-D - male
- RoHS
- Black
- Limited lifetime warranty
- DVI cable
- American Wire Gauge (AWG)
- 28
- TMDS Links
- Dual link
- Plated Connector
- Nickel
- Length
- 2 m
- Black
- Connector
- 24+1 pin digital DVI - male
- RoHS
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £8.48 |
StarTech.com Mini DisplayPort to DVI Video Adapter Converter | In Stock | £9.72 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £9.22 |
StarTech.com 5m DVI-D Dual Link Cable – M/M | In Stock | £15.88 |
StarTech.com 1 ft DVI-D to 2x DVI-D Digital Video Splitter Cable - M/F | In Stock | £12.18 |
StarTech.com 2m DVI-D Dual Link Cable – M/M | In Stock | £9.17 |
StarTech.com 3m DVI-D Dual Link Cable – M/M | In Stock | £11.55 |
StarTech.com 1m DVI-D Dual Link Cable – M/M | In Stock | £7.82 |
