Provides a high-speed, crystal-clear connection to your DVI digital devices. The DVIDDMM1M 1m DVI-D Dual Link cable features 2 male DVI (25-pin) connectors and provides a reliable, purely digital connection between your desktop or laptop computer and a DVI-D monitor or projector.
The 1m DVI-D digital monitor cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec and is fully compliant with DVI DDWG standards.
- StarTech.com 1m DVID Dual Link Cable M/M - DVI cable - 1 m
- DVI cable - dual link
- Technology
- Shielded
- Thumbscrews
- Length
- 1 m
- Connector
- DVI-D - male
- Connector (Second End)
- DVI-D - male
- RoHS
- Black
- Limited lifetime warranty
- DVI cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 28
- TMDS Links
- Dual link
- Plated Connector
- Nickel
- Thumbscrews
- Length
- 1 m
- Black
- Connector
- 24+1 pin digital DVI - male
- RoHS
StarTech.com 5m DVI-D Dual Link Cable – M/M | In Stock | £15.88 |
StarTech.com 10m DVI-D Dual Link Cable – M/M | In Stock | £43.94 |
StarTech.com 2m DVI-D Dual Link Cable – M/M | In Stock | £9.17 |
StarTech.com 3m DVI-D Dual Link Cable – M/M | In Stock | £11.55 |
StarTech.com 1m DVI-D Dual Link Cable – M/M | In Stock | £7.82 |
