StarTech.com 2m DVI-D Dual Link Cable – M/M
Quicklinx: 7RWJWS00 Mfr#: DVIDDMM2M
Length: 2m
£9.32 ex VAT
£11.18 inc VAT
Provides a high-speed, crystal-clear connection to your DVI digital devices. The DVIDDMM2M 2m DVI-D Dual Link cable features 2 male DVI (25-pin) connectors and provides a reliable, purely digital connection between your desktop or laptop computer and a DVI-D monitor or projector.
The 2m DVI-D digital monitor cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec and is fully compliant with DVI DDWG standards.
  • Reliable connection
    The DVI cable features male connectors on both ends, ensuring a secure connection that minimizes signal loss during video transmission.
  • High-resolution support
    Ideal for high-definition displays, the cable supports resolutions up to 2560 x 1600, making it suitable for a wide range of applications from gaming to professional presentations.
  • Durable construction
    Constructed with 28 AWG wire, this cable provides durability and strength to withstand everyday use while maintaining excellent performance.
  • Easy compatibility
    Designed for devices with a 24+1 pin digital DVI output, this cable offers compatibility with a variety of monitors and computers.
StarTech.com 2m DVI-D Dual Link Cable - Male to Male DVI-D Digital Video Monitor Cable - 25 pin DVI-D Cable M/M Black 2 Meter - 2560x1600 (DVIDDMM2M) - DVI cable - 2 m
DVI cable - dual link
Length
2 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - male
RoHS
DVI cable
American Wire Gauge (AWG)
28
TMDS Links
Dual link
Plated Connector
Nickel
Length
2 m
Connector
24+1 pin digital DVI - male
RoHS
7RWJ StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.55
7RWJ StarTech.com Mini DisplayPort to DVI Video Adapter Converter In Stock £9.55
7RWJ StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £9.00
7RWJ StarTech.com 5m DVI-D Dual Link Cable – M/M In Stock £15.49
7RWJ StarTech.com 1 ft DVI-D to 2x DVI-D Digital Video Splitter Cable - M/F In Stock £11.88
7RWJ StarTech.com 2m DVI-D Dual Link Cable – M/M In Stock £9.32
7RWJ StarTech.com 1m DVI-D Dual Link Cable – M/M In Stock £7.62
Length: 2m
