StarTech.com 2m Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M
Quicklinx: 85F7WS00 Mfr#: MXTMMHQ2M
Type: VGA
Length: 2m
More than 50 In Stock
£7.32 ex VAT
£8.78 inc VAT
Connect your VGA monitor with the highest quality connection available. The MXTMMHQ2M High Resolution VGA Cable (2-meter) is designed to provide the highest video quality possible through VGA, ideally suited for high resolution applications of 1920x1200 and above.
This durably constructed coaxial VGA video cable (HD15 to HD15) eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial VGA cables, while delivering superior EMI interference protection by using ferrite cores near the connector ends.
  • High-quality construction
    Featuring triple shielded twisted pair coaxial technology, this cable significantly reduces interference, allowing for high-resolution video transmission without degradation.
  • Secure connectors
    Equipped with 15 pin HD D-Sub connectors on both ends, which offer a reliable and firm connection, minimizing the chance of disconnections during use.
  • Durable and reliable
    Constructed with aluminum mylar foil shielding and a durable molded design, the cable is built to withstand daily use while providing consistent performance.
  • Environmentally compliant
    This cable adheres to RoHS standards, ensuring it is free from hazardous materials, making it a safe choice for users who are environmentally conscious.
StarTech.com 2m Coax High Resolution Monitor VGA Video Cable HD15 M/M - VGA cable - 2 m
VGA cable
Triple shielded twisted pair coaxial
Molded
Length
2 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
RoHS
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Molded
Length
2 m
Connector
RoHS
85F7 StarTech.com Slimline Adapter HDDB15 F/F In Stock £5.33
85F7 StarTech.com 15m Coax High Resolution Monitor VGA Cable - HD15 M/M In Stock £40.88
85F7 StarTech.com 1m Monitor VGA Cable In Stock £6.05
85F7 StarTech.com 2m Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £7.32
85F7 StarTech.com 3m Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £10.25
Type: VGA
Length: 2m
Stock Status: Clearance
