Connect your VGA monitor with the highest quality connection available. This 15-meter high resolution VGA monitor cable is designed to provide the highest video quality possible through VGA.
Ideally suited for high resolution VGA applications, this high quality male-to-male coaxial VGA cable eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
- StarTech.com 15m Coax High Resolution Monitor VGA Cable HD15 M/M - VGA cable - 15 m
- VGA cable
- Technology
- Triple shielded twisted pair coaxial
- Molded
- Length
- 15 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- RoHS
- Black
- Limited lifetime warranty
- VGA cable
- Technology
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Molded
- Length
- 15 m
- Black
- Connector
- 15 pin HD D-Sub (HD-15) - male
- RoHS
StarTech.com Slimline Adapter HDDB15 F/F | In Stock | £5.33 |
StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F | In Stock | £6.85 |
StarTech.com 2m Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M | In Stock | £7.32 |
StarTech.com 3m Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M | In Stock | £10.25 |
