StarTech.com 2m 6 ft Long Down Angle Apple 30-pin Dock Connector to USB Cable - Stepped Connector
Quicklinx: 8HN0WS00 Mfr#: USB2ADC2MD
Charge or Sync your wall/stand-mounted iPhone, iPod or iPad with the cable out of the way. The USB2ADC2MD Dock Connector to USB cable for iPhone, iPod and iPad (2m) features a down-angled Apple (30-pin) Dock Connector, which is ideal for wall-mounted or stand-mounted applications because it positions the cable behind your iOS-enabled mobile digital device for a neater installation that keeps the cable out of the way.
The longer USB to iPhone cable design offers 2-meters in cable length to overcome distance restrictions while still providing full charging power.
Plus, this uniquely constructed Dock Connector to USB cable features a stepped Apple Dock Connector, designed by StarTech.com, which unlike a regular connector plugs into your iPhone, iPod or iPad, even when inside a protective case while avoiding the inconvenience of having to constantly remove the cover for every charge/sync.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 2m 30-pin Dock to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
StarTech.com 2m Down Angle Apple 30-pin Dock to USB Cable iPhone iPod iPad - charging / data cable - 2 m
Cable
Charging / data cable
Shielded
American Wire Gauge (AWG)
24
Length
2 m
White
Connector
USB - male
Connector (Second End)
Apple Dock - male
Angled connector
Apple iPod (4G, 5G); iPod classic; iPod mini
Cable Type
Charging / data cable angled connector
Shielded
24
Jacket Material
PVC
Shielding Material
Length
2 m
Plated Connector
Nickel
Sync and charge
White
Connector
4 pin USB Type A - male
Apple Dock connector - male
RoHS, MFI
Limited warranty - lifetime
Apple iPod (4G, 5G) , Apple iPod classic , Apple iPod mini
