The MUHSMF2M 4-Pole 3.5mm headset extension cable (2m) features a 3.5mm (1/8" TRRS) audio connector on one end and a 3.5mm (1/8" TRRS) audio connector on the other, making it easy to extend the reach between your hands-free headset or headphones, and your iPhone, mobile phone or laptop computer.
To ensure long-lasting performance, this high quality 3.5mm audio extension cable features molded PVC strain relief at each of the 1/8" TRRS connectors, which prevents the cable termination points from bending at sharp angles, in turn reducing the risk of cable damage.
To ensure proper hardware detection, it's recommended that the external headset be plugged into the adapter first, before the adapter is connected to the computer or mobile device.
Durable construction
The cable features molded connectors and a robust PVC jacket, offering resistance against wear and tear while ensuring reliable performance in daily use. -
Strain relief technology
Incorporating strain relief at the connection points, this cable minimizes the risk of damage, prolonging the lifespan of your audio connections. -
High-quality connectors
With nickel-plated connectors, this extension cable enhances audio quality by reducing potential interference, ensuring crisp and clear sound transmission.
- StarTech.com 2m 3.5mm 4 Position TRRS Headset Extension Cable - M/F - audio Extension Cable for iPhone (MUHSMF2M) - headset extension cable - 2 m
- Cable
- Headset extension cable
- American Wire Gauge (AWG)
- 28
- Length
- 2 m
- Black
- Connector
- 4-pole mini jack - male
- Connector (Second End)
- 4-pole mini jack - female
- Moulded, strain relief
- Limited lifetime warranty
- Designed For
- P/N: MUYHSFMM, MUYHSMFF, MUYHSMFFADW, SV211DPUA, SV211DPUA4K, SV211HDUA4K
- Cable Type
- 28
- Jacket Material
- PVC
- Length
- 2 m
- Plated Connector
- Nickel
- Black
- Connector
- Mini-phone 3.5 mm 4-pole - male
- Mini-phone 3.5 mm 4-pole - female
- RoHS
- Limited warranty - lifetime
- Designed For
StarTech.com 6 ft 3.5mm Stereo Audio Cable - M/M | In Stock | £4.64 |
StarTech.com 6 ft 3.5mm Stereo Extension Audio Cable - M/F | In Stock | £4.82 |
StarTech.com 12 ft PC Speaker Extension Audio Cable | In Stock | £5.33 |
StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.50 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.48 |
StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.06 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.78 |
StarTech.com 3.5mm 4 Position to 2x 3 Position 3.5mm Headset Splitter Adapter - F/M | In Stock | £7.79 |
StarTech.com 3.5mm 3 Pin Headset Splitter | In Stock | £3.64 |
StarTech.com 2m 3.5mm 4 Position TRRS Headset Extension Cable - M/F | In Stock | £6.14 |
StarTech.com 4 Position to 2x 3 Pin 3.5mm Headset Splitter Adapter - White | In Stock | £3.57 |
