StarTech.com 2m 3.5mm 4 Position TRRS Headset Extension Cable - M/F
Quicklinx: 87MYWS00 Mfr#: MUHSMF2M
Length: 2m
Select:
30 In Stock
£6.20 ex VAT
£7.44 inc VAT
The MUHSMF2M 4-Pole 3.5mm headset extension cable (2m) features a 3.5mm (1/8" TRRS) audio connector on one end and a 3.5mm (1/8" TRRS) audio connector on the other, making it easy to extend the reach between your hands-free headset or headphones, and your iPhone, mobile phone or laptop computer.
To ensure long-lasting performance, this high quality 3.5mm audio extension cable features molded PVC strain relief at each of the 1/8" TRRS connectors, which prevents the cable termination points from bending at sharp angles, in turn reducing the risk of cable damage.
To ensure proper hardware detection, it's recommended that the external headset be plugged into the adapter first, before the adapter is connected to the computer or mobile device.
  • Durable construction
    The cable features molded connectors and a robust PVC jacket, offering resistance against wear and tear while ensuring reliable performance in daily use.
  • Strain relief technology
    Incorporating strain relief at the connection points, this cable minimizes the risk of damage, prolonging the lifespan of your audio connections.
  • High-quality connectors
    With nickel-plated connectors, this extension cable enhances audio quality by reducing potential interference, ensuring crisp and clear sound transmission.
StarTech.com 2m 3.5mm 4 Position TRRS Headset Extension Cable - M/F - audio Extension Cable for iPhone (MUHSMF2M) - headset extension cable - 2 m
Cable
Headset extension cable
American Wire Gauge (AWG)
28
Length
2 m
Connector
4-pole mini jack - male
Connector (Second End)
4-pole mini jack - female
Moulded, strain relief
P/N: MUYHSFMM, MUYHSMFF, MUYHSMFFADW, SV211DPUA, SV211DPUA4K, SV211HDUA4K
Cable Type
28
Jacket Material
PVC
Length
2 m
Plated Connector
Nickel
Connector
Mini-phone 3.5 mm 4-pole - male
Mini-phone 3.5 mm 4-pole - female
RoHS
Limited warranty - lifetime
87MY StarTech.com 6 ft 3.5mm Stereo Audio Cable - M/M In Stock £4.60
87MY StarTech.com 6 ft 3.5mm Stereo Extension Audio Cable - M/F In Stock £4.89
87MY StarTech.com 12 ft PC Speaker Extension Audio Cable In Stock £5.37
87MY StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £2.97
87MY StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.97
87MY StarTech.com 3.5mm 4 Position to 2x 3 Position 3.5mm Headset Splitter Adapter - F/M In Stock £7.79
87MY StarTech.com 3.5mm 3 Pin Headset Splitter In Stock £3.62
87MY StarTech.com 2m 3.5mm 4 Position TRRS Headset Extension Cable - M/F In Stock £6.20
87MY StarTech.com 4 Position to 2x 3 Pin 3.5mm Headset Splitter Adapter - White In Stock £3.47
Length: 2m
