StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k
Quicklinx: 84MJWS00 Mfr#: MDP2DPMM2MW
Length: 2m
£12.74 ex VAT
£15.28 inc VAT
Connect your DisplayPort monitor to a Mini DisplayPort source. The MDP2DPMM2MW 2-meter Mini DisplayPort to DisplayPort Adapter Cable, features a Mini DisplayPort (male) connector on one end, and a DisplayPort (male) connector on the other, allowing you to connect any Mini DisplayPort-equipped laptop (including the Mac family of products) to an HDTV, monitor or projector that uses a standard DisplayPort connection.
StarTech.com 2m 6 ft White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k with HBR2 support - Mini DP to DP Cable (MDP2DPMM2MW) - DisplayPort cable - 2 m
DisplayPort cable
Shielded
Drain wire
Length
2 m
Connector
Mini DisplayPort - male
Connector (Second End)
DisplayPort - male
RoHS
White
P/N: CDP2MDP, CDP2MDPEC, CDP2MDPFC, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDMDP, HD2DP
DisplayPort cable
Shielded
Shielding Material
Aluminum mylar foil
American Wire Gauge (AWG)
32
Plated Connector
Gold
Drain wire
Length
2 m
White
Connector
20 pin DisplayPort - male
RoHS
84MJ StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.12
84MJ StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F In Stock £9.42
84MJ StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F In Stock £15.72
84MJ StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £10.43
84MJ StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £12.74
84MJ StarTech.com 3m (10 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £15.35
84MJ StarTech.com 1m (3 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k In Stock £14.48
84MJ StarTech.com 2m (6 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k In Stock £5.85
84MJ StarTech.com 3m (10 ft) White Mini DisplayPort Cable - M/M In Stock £7.06
Length: 2m
