Connect your DisplayPort monitor to a Mini DisplayPort source. The MDP2DPMM2MW 2-meter Mini DisplayPort to DisplayPort Adapter Cable, features a Mini DisplayPort (male) connector on one end, and a DisplayPort (male) connector on the other, allowing you to connect any Mini DisplayPort-equipped laptop (including the Mac family of products) to an HDTV, monitor or projector that uses a standard DisplayPort connection.
- StarTech.com 2m 6 ft White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k with HBR2 support - Mini DP to DP Cable (MDP2DPMM2MW) - DisplayPort cable - 2 m
- DisplayPort cable
- Technology
- Shielded
- Drain wire
- Length
- 2 m
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- DisplayPort - male
- RoHS
- White
- Limited lifetime warranty
- Designed For
- P/N: CDP2MDP, CDP2MDPEC, CDP2MDPFC, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDMDP, HD2DP
- DisplayPort cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil
- American Wire Gauge (AWG)
- 32
- Plated Connector
- Gold
- Drain wire
- Length
- 2 m
- White
- Connector
- 20 pin DisplayPort - male
- RoHS
- Designed For
StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £9.06 |
StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F | In Stock | £9.31 |
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F | In Stock | £13.52 |
StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F | In Stock | £15.58 |
StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £10.43 |
StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £12.60 |
StarTech.com 3m (10 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £15.35 |
StarTech.com 1m (3 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k | In Stock | £14.48 |
StarTech.com 2m (6 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k | In Stock | £16.38 |
StarTech.com 3m (10 ft) White Mini DisplayPort Cable - M/M | In Stock | £17.45 |
