Confidentiality Screen Filter Blue Light Reduction Matte or Glossy 2-Year Warranty. The monitor privacy screen is easy to attach and remove. Simply attach the 27 inch privacy cover to your computer display using the attachment strips or slide-mount tabs. This confidentiality screen filter is also reversible. The matte side provides you with glare reduction and the glossy side of the privacy screen will provide you with increased clarity.
Protect Your Privacy
The privacy screen protector for desktop monitors is a great investment if you want to protect your privacy and security. It is a convenient and cost-effective way to keep your classified information, intellectual property or any other important data you wish to keep protected. You can have a peace of mind while working in the office or public environments because you know your widescreen is protected with the 30+/- degree privacy viewing angle.
The monitor privacy film is designed to filter blue light (390nm~480 wavelength) that can cause eye strain and can disrupt sleeping patterns.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
The TAA compliant PRIVSCNMON27 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
The privacy screen protector for desktop monitors is a great investment if you want to protect your privacy. It is a convenient and cost-effective way to keep your classified information, intellectual property or any other important data you wish to keep protected. You can have a peace of mind while working in the office or public environments because you know your screen is protected with the 30+/- degree privacy viewing angle. The cutout on the top corner of the privacy screen makes it easy to remove for sharing content with trusted audiences or switching between finishes. -
Lowering blue light exposure is important. To reduce digital eye strain, the monitor privacy film blocks between 40% to 51% of the blue light in the wavelength range of 380nm to 480nm. -
Antimicrobial Protection
Our privacy screens feature an anti-microbial coating on the matte-side of the filter. Embedded antimicrobial technology provides protection against bacterial microbes by continuously eliminating up to 99.99% of certain surface bacteria. Antimicrobial screen protectors are ideal for environments where disinfection is important. -
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales. The TAA compliant PRIVSCNMON27 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech Monitor Privacy Screen for 27 inch PC Display, Computer Screen Security Filter, Blue Light Reducing Screen Protector Film, 16:9 WideScreen, Matte/Glossy, +/-30 Degree Viewing - Blue Light Filter - display privacy filter - 27" wide - TAA Compliant
- Product Type
- Display privacy filter
- Package Content
- Adhesive strips, slide mount tabs
- Transparent
- Display Screen Size Compatibility
- 27" wide
- Product Material
- Plastic
- 59.767 cm x 33.6 cm x 0.2 cm
- 395 g
- TAA Compliant
- 2-year warranty
- Designed For
- P/N: ARMPIVOTE2, ARMUNONB1, FPPNEUSTND
- Product Type
- Package Content
- 27" wide
- Product Material
- Plastic
- 59.767 cm - 33.6 cm - 0.2 cm
- 395 g
- Shipping Dimensions (WxDxH) / Weight
- 68 cm x 44 cm x 0.6 cm / 500 g
- Transparent
Display Filter
- Aspect Ratio
- 16:9
- Mounting Kit
- Included
- Anti-glare, matte, glossy surface, +/- 30° visible angle, blue light reduction
- RoHS, REACH, GSA
- TAA Compliant
- Limited warranty - 2 years
- Designed For
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £54.54 |
StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £61.12 |
StarTech.com 34in. Monitor Privacy Screen - Ultrawide - Matte / Glossy | In Stock | £121.95 |
StarTech.com 19in. Monitor Privacy Screen | In Stock | £49.06 |
StarTech.com 18.5in. Monitor Privacy Screen | In Stock | £47.82 |
StarTech.com 20in. Monitor Privacy Screen | In Stock | £53.54 |
StarTech.com 22in. Monitor Privacy Screen | In Stock | £59.05 |
StarTech.com 23in. Monitor Privacy Screen | In Stock | £61.09 |
StarTech.com 24in. Monitor Privacy Screen | In Stock | £66.47 |
StarTech.com 23.8in. Monitor Privacy Screen | In Stock | £59.40 |
StarTech.com Privacy Screen Adhesive Strips | In Stock | £6.33 |
StarTech.com 17" Monitor Privacy Filter | In Stock | £9.01 |
StarTech.com 19" Monitor Privacy Filter | In Stock | £48.19 |
StarTech.com 19.5" Monitor Privacy Filter | In Stock | £49.05 |
StarTech.com 22" Monitor Privacy Filter | In Stock | £57.68 |
StarTech.com 23.6" Monitor Privacy Filter | In Stock | £61.87 |
StarTech.com 28" Monitor Privacy Filter | In Stock | £85.94 |
StarTech.com 23.8-inch Gold Privacy Screen | In Stock | £67.75 |
StarTech.com 24-inch Gold Privacy Screen | In Stock | £74.19 |
StarTech.com 24-inch Gold Privacy Screen | In Stock | £70.29 |
StarTech.com 27-inch Gold Privacy Screen | In Stock | £92.20 |
