StarTech.com 27-inch Gold Privacy Screen
Quicklinx: HKKPWS00 Mfr#: 2769G-PRIVACY-SCREEN
Accessory Type: Privacy Screen
Hurry, only 2 left in stock!
£83.81 ex VAT
£100.57 inc VAT
This Monitor Privacy Screen features a universal design compatible with 27-inch monitors with a 16:9 aspect ratio. Gold privacy screens are more reflective than black filters, helping to improve visual privacy when working in an office or public environment.
  • Prevent Visual Eavesdropping
    The gold security filter is a convenient solution that features a quick shift to a mirror-like effect to protect confidential data from unwanted viewers, while maintaining a clear view of 60 degrees (+/- 30 degrees from the center) for the user.
  • Reversible Filter
    The privacy screen protector is reversible. The glossy gold and black sides offer maximum privacy and help maintain color vibrancy. The privacy shield provides a light transmittance of 57.5%, providing optimal screen brightness and enhanced levels of privacy. The detachable design allows you to switch effortlessly between gold and black finishes.
  • Hassle-free Installation
    Attach the privacy screen shield using the provided residue-free transparent adhesive strips or the side mounting tabs. The cut-out on the top corner of the privacy screen makes it easy to remove for sharing content with a trusted audience or switching between the gold and black finishes.
  • Blue Light Reduction
    Reduce eye strain and improve visual comfort by reducing blue light exposure. The computer monitor filter blocks up to 51% of the blue light emitted from the display in the 380nm - 480nm wavelength range. Digital eye strain can lead to symptoms like headaches, dry eyes, and blurred vision.
StarTech.com 27-inch 16:9 Gold Monitor Privacy Screen, Reversible Filter w/Enhanced Privacy, Glossy Computer Security Filter, Removable Screen Protector/Shield, +/- 30 Deg. - display privacy filter - 27"
Display privacy filter - 2-way
Installation Type
Removable - plug-in/adhesive
Package Content
Cleaning cloth, slide mount tabs, 2 adhesive strips
Black, gold
Display Screen Size Compatibility
27"
Product Material
Plastic
59.8 cm x 33.7 cm x 0.05 cm
230 g
Package Content
27"
Product Material
Plastic
59.8 cm - 33.7 cm - 0.05 cm
230 g
74 cm x 42.5 cm x 0.6 cm / 600 g
Black, gold
Display Filter
Privacy Protection
2-way
Installation Type
Aspect Ratio
16:9
Surface Finish
Glossy
Mounting Kit
Included
+/- 30° visible angle, 51% blue light reduction
HKKP StarTech.com Privacy Screen Adhesive Strips In Stock £6.09
