StarTech.com 25U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks
Quicklinx: 9TV1WS00 Mfr#: 4POSTRACK25U
Depth (mm): 66.18cm
Type: Floor standing
U Height: 25U
Width (mm): 60cm
13 In Stock
£197.30 ex VAT
£236.76 inc VAT
Store your servers, network and telecommunications equipment in an adjustable 25U open-frame rack. The 4POSTRACK25U 25U Server Rack lets you store your servers, network and telecommunications equipment in a sturdy, adjustable depth open-frame rack.
Designed with ease of use in mind, this 25U rack offers easy-to-read markings for both rack units (U) and depth, with a wide range of mounting depth adjustments (22 - 40in) that make it easy to adapt the rack to fit your equipment.
This durable 4-post rack supports a static loading capacity of up to 1200lbs (544kg), and offers compliance with several industry rack standards (EIA/ECA-310, IEC 60297, DIN 41494) for a universal design that's compatible with most rack equipment.
For a complete server storage solution that saves you time and hassle, the rack includes optional accessories such as casters, leveling feet and cable management hooks. The base is also pre-drilled for securely fastening the rack to the floor if needed, providing you with additional stability to better suit your server environment..
  • Durable material
    Constructed from steel, this rack provides durability and strength for housing heavy equipment.
  • Package contents
    Includes components such as screws, brackets, and casters, facilitating an easy assembly and setup process.
  • Adaptable design
    This open frame rack offers adjustable depth, making it suitable for various server or network equipment needs.
  • Weight capacity
    Supports a substantial weight limit of 544 kg, ensuring stability and reliability for housed equipment.
  • Standards compliance
    Designed in accordance with EIA-310-E, RoHS, and other standards, ensuring quality and compatibility.
StarTech.com 25U 19" Open Frame Server Rack, 4 Post Adjustable Depth 22-40" Mobile, Free Standing Rolling Network/Computer Equipment Data Rack, Dell PowerEdge, HP ProLiant ThinkServer - Adjustable Server Rack (4POSTRACK25U) - rack - 25U
Rack
Rack Type
Open frame
Package Content
Phillips screwdriver, 16 M6 screws, 2 base brackets, 2 top brackets, 48 M8 bolts, 8 corner sections, 48 M8 washers, M8 (13mm) wrench, 4 casters, 4 x levelling feet, 16 M6 flange nuts, 32 PVC cup washers, 32 M6 cage nuts, M6 (10mm) wrench, 4 x centre sections, 2 right vertical rails, 2 left vertical rails, 4 grounding wires, 16 M6 flat washers, 12 hook mounting screws, 12 cable management hooks, 32 M6 Phillips screws
Height (Rack Units)
25U
Product Material
Steel
60 cm x 66.18 cm x 121.9 cm
20 kg
Adjustable depth, flat pack, 4 post rack mountable, 4 post
P/N: CABCAGENT62B, CABCAGENTS62, CABCAGENUT2B, CABCAGENUT6B, CABCAGENUTS2, CABCAGENUTSB, CABSCREWM52B, CABSCREWM5B, CABSCREWM62B, CABSCREWM6B, CABSCREWSB, CABSCREWSM5, CABSCREWSM5B, CABSCREWSM62, CABSCREWSM6B, CABSCRWS1224, CABSCRWSM62B
Rack
Rack Type
Open frame
Product Material
Steel
Package Content
Height (Rack Units)
25U
60 cm
66.18 cm
121.9 cm
20 kg
Inner Dimensions
46.5 cm x 55.9 cm x 111.58 cm
Weight Limit
544 kg
Mounting Kit
Included
EIA-310-E, RoHS, DIN 41494, IEC 60297-3-100, ECA-310-E
Limited warranty: - 2 years , Technical support: - lifetime
9TV1 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £94.63
9TV1 StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £45.84
9TV1 StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £79.45
9TV1 StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
9TV1 StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
9TV1 StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £30.71
9TV1 StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £464.07
9TV1 StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £351.41
9TV1 StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.44
9TV1 StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
9TV1 StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
9TV1 StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
9TV1 StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.30
9TV1 StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf In Stock £93.48
9TV1 StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £527.07
9TV1 StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £280.59
9TV1 StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £324.85
9TV1 StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £543.36
9TV1 StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £86.88
9TV1 StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets In Stock £102.81
9TV1 StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £62.88
9TV1 StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £72.65
9TV1 StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £77.01
9TV1 StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £15.50
9TV1 StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £76.49
9TV1 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £83.04
9TV1 StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £56.70
9TV1 StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £44.28
9TV1 StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £37.00
9TV1 StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £51.38
9TV1 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
9TV1 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.24
9TV1 StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.36
9TV1 StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.59
9TV1 StarTech.com 42U Adjustable Depth Open Frame 4 Post Server Rack Cabinet - Casters Levelers and Hooks In Stock £208.39
9TV1 StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg In Stock £158.72
9TV1 StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 125lbs / 56.7kg In Stock £162.14
9TV1 StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £47.16
9TV1 StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.75
9TV1 StarTech.com 25U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks In Stock £197.30
9TV1 StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £23.11
9TV1 StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks In Stock £169.35
9TV1 StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.58
9TV1 StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
9TV1 StarTech.com 25U 36in Server Rack Cabinet In Stock £730.55
9TV1 StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
9TV1 StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
9TV1 StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £53.55
9TV1 StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
9TV1 StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
9TV1 StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
9TV1 StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.01
9TV1 StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
9TV1 Startech.com 100 Pkg M6 Mounting Screws In Stock £26.84
9TV1 StarTech.com 19in Cable Management Panel In Stock £24.18
9TV1 StarTech.com Vented 1U Rack Shelf - 10in In Stock £21.05
9TV1 StarTech.com 15U Open Frame Rack - 4 Post - 22-40 in. Adjustable Depth In Stock £192.13
9TV1 StarTech.com 18U Open Frame Rack - 4 Post - 22-40 in. Adjustable Depth In Stock £196.63
9TV1 StarTech.com 8U Open Frame Rack - 4 Post - 22-40 in. Adjustable Depth In Stock £151.64
9TV1 StarTech.com Heavy Duty Casters for Server Racks/Cabinets - Set of 4 In Stock £36.61
9TV1 StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
Depth (mm): 66.18cm
U Height: 25U
Width (mm): 60cm
