StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch
Quicklinx: 7P3HWS00 Mfr#: SV831DVIU
Type: KVM switch
Connectivity: KVM
Ports: 8
Hurry, only 3 left in stock!
£618.82 ex VAT
£742.58 inc VAT
Control up to 8 USB computers with DVI or HDMI video, from one keyboard, mouse and monitor. The SV831DVIU 8-Port 1U Rack Mount DVI USB KVM Switch lets you control up to 8 USB-connected computers (each with DVI or HDMI display output) from a single keyboard, mouse and monitor.
The KVM switch offers maximum control, allowing you to switch computers using hot-key commands or front panel push-buttons. Supporting digital resolutions up to 1920x1200 via DVI or HDMI connection (using DVI to HDMI adapter), the KVM provides the high resolutions recommended for newer displays, allowing you to take full advantage of your monitor/screen capability.
A perfect addition to any server room or software test lab, this rugged 8-port switch can be rack-mounted into 1U of cabinet space.
This KVM supports digital signals only, and cannot be used with DVI-to-VGA adapters.
StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch - USB DVI KVM Switch - DVI KVM Switch - USB KVM Switch (SV831DVIU) - KVM switch - 8 ports - rack-mountable
Enclosure Type
Rack-mountable 1U
Subtype
KVM
Ports
8 x KVM port(s)
KVM Users Qty
1 local user
AC 120/230 V
43.8 cm x 18 cm x 4.4 cm
3.5 kg
3-year warranty
P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25U, 4POSTRACK42, RACKCOND17HD, RK1233BKM, RK1236BKF, RK12OD2, RK1833BKM, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK8OD, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12, SVA12M5NA
Enclosure Type
Rack-mountable 1U
Subtype
KVM
Ports
8 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1200
Status Indicators
Port status, power
8 x USB 2.0 Type B , 8 x DVI-D , 1 x DVI-D , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A
Internal power supply
AC 120/230 V
Rack Mounting Kit
Included
FCC, RoHS
43.8 cm
18 cm
4.4 cm
3.5 kg
Limited warranty - 3 years
0 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RACKCOND17HD, RK1233BKM, RK1236BKF, RK12OD, RK12OD2, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK8OD, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12, SVA12M5NA
7P3H StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
7P3H StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £249.28
7P3H StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £115.45
7P3H StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £131.32
7P3H StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £464.07
7P3H StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £527.07
7P3H StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £280.59
7P3H StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £317.20
7P3H StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £543.36
Type: KVM switch
Connectivity: KVM
Ports: 8
Price Range Ex VAT: £500 - £750
