Store your servers, network and telecommunications equipment in an adjustable 25U open-frame rack. The 4POSTRACK25U 25U Server Rack lets you store your servers, network and telecommunications equipment in a sturdy, adjustable depth open-frame rack.
Designed with ease of use in mind, this 25U rack offers easy-to-read markings for both rack units (U) and depth, with a wide range of mounting depth adjustments (22 - 40in) that make it easy to adapt the rack to fit your equipment.
This durable 4-post rack supports a static loading capacity of up to 1200lbs (544kg), and offers compliance with several industry rack standards (EIA/ECA-310, IEC 60297, DIN 41494) for a universal design that's compatible with most rack equipment.
For a complete server storage solution that saves you time and hassle, the rack includes optional accessories such as casters, leveling feet and cable management hooks. The base is also pre-drilled for securely fastening the rack to the floor if needed, providing you with additional stability to better suit your server environment..
- StarTech.com 25U 19" Open Frame Server Rack, 4 Post Adjustable Depth 22-40" Mobile, Free Standing Rolling Network/Computer Equipment Data Rack, Dell PowerEdge, HP ProLiant ThinkServer - Adjustable Server Rack (4POSTRACK25U) - rack - 25U
- Product Type
- Rack
- Rack Type
- Open frame
- Package Content
- Phillips screwdriver, 16 M6 screws, 2 base brackets, 2 top brackets, 48 M8 bolts, 8 corner sections, 48 M8 washers, M8 (13mm) wrench, 4 casters, 4 x levelling feet, 16 M6 flange nuts, 32 PVC cup washers, 32 M6 cage nuts, M6 (10mm) wrench, 4 x centre sections, 2 right vertical rails, 2 left vertical rails, 4 grounding wires, 16 M6 flat washers, 12 hook mounting screws, 12 cable management hooks, 32 M6 Phillips screws
- Black
- Height (Rack Units)
- 25U
- Product Material
- Steel
- 60 cm x 66.18 cm x 121.9 cm
- 20 kg
- Adjustable depth, flat pack, 4 post rack mountable, 4 post
- 2-year warranty
- Designed For
- P/N: CABCAGENT62B, CABCAGENTS62, CABCAGENUT2B, CABCAGENUT6B, CABCAGENUTS2, CABCAGENUTSB, CABSCREWM52B, CABSCREWM5B, CABSCREWM62B, CABSCREWM6B, CABSCREWSB, CABSCREWSM5, CABSCREWSM5B, CABSCREWSM62, CABSCREWSM6B, CABSCRWS1224, CABSCRWSM62B
- Product Type
- Rack
- Rack Type
- Open frame
- Product Material
- Steel
- Package Content
- 25U
- 60 cm
- 66.18 cm
- 121.9 cm
- 20 kg
- Inner Dimensions
- 46.5 cm x 55.9 cm x 111.58 cm
- Black
- Weight Limit
- 544 kg
- Mounting Kit
- Included
- EIA-310-E, RoHS, DIN 41494, IEC 60297-3-100, ECA-310-E
- Limited warranty: - 2 years , Technical support: - lifetime
- Designed For
StarTech.com 16 Port 1U Rackmount USB PS/2 KVM Switch with OSD | In Stock | £490.32 |
StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet | In Stock | £19.93 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg | In Stock | £99.99 |
StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet | In Stock | £48.25 |
StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails | In Stock | £83.08 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £13.74 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £35.39 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £34.53 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £551.61 |
StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) | In Stock | £337.14 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £16.28 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £32.84 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £62.33 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £65.84 |
StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg | In Stock | £28.76 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £575.96 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £292.39 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £319.01 |
StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch | In Stock | £657.69 |
StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg | In Stock | £92.59 |
StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets | In Stock | £120.51 |
StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £68.86 |
StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £88.30 |
StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel | In Stock | £35.51 |
StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg | In Stock | £77.10 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg | In Stock | £92.81 |
StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg | In Stock | £55.50 |
StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg | In Stock | £45.85 |
StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg | In Stock | £39.89 |
StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg | In Stock | £53.98 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) | In Stock | £4.31 |
StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) | In Stock | £7.01 |
StarTech.com 42U Adjustable Depth Open Frame 4 Post Server Rack Cabinet - Casters Levelers and Hooks | In Stock | £252.52 |
StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel | In Stock | £46.16 |
StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £20.58 |
StarTech.com 25U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks | In Stock | £237.02 |
StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £25.63 |
StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks | In Stock | £205.22 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £65.84 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £32.13 |
StarTech.com 25U 36in Server Rack Cabinet | In Stock | £723.01 |
StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £22.74 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £34.53 |
StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £17.25 |
StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £62.33 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £32.84 |
StarTech.com 50 Pkg M5 Mounting Screws | In Stock | £18.34 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £34.53 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £19.35 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £26.55 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £30.84 |
Startech.com 100 Pkg M6 Mounting Screws | In Stock | £28.59 |
StarTech.com 19in Cable Management Panel | In Stock | £24.78 |
StarTech.com Vented 1U Rack Shelf - 10in | In Stock | £21.11 |
StarTech.com 15U Open Frame Rack - 4 Post - 22-40 in. Adjustable Depth | In Stock | £225.59 |
StarTech.com 18U Open Frame Rack - 4 Post - 22-40 in. Adjustable Depth | In Stock | £219.17 |
StarTech.com 8U Open Frame Rack - 4 Post - 22-40 in. Adjustable Depth | In Stock | £169.75 |
StarTech.com M6 Mounting Screws 50Pack | In Stock | £17.54 |
