StarTech.com's DuraRak 25U 4 Post Open Frame Rack/Cabinet provides a durable, open air housing for rackmount servers and networking equipment. The equipment rack/cabinet features heavy gauge mounting rails to ensure a stable installation platform and adjustable posts for flexible installation. The 25U rack is compliant with EIA-RS-310C standards, offering a universal design that's compatible with equipment from popular manufacturers. Plus, the equipment rack is flat-packed, reducing shipping costs and simplifying handling and assembly. The DuraRak 25U 4-Post Open Racks offer a durable housing for valuable equipment.
- StarTech.com 25U Open Frame Server Rack - 994lb Capacity - 4 Post Adjustable Depth (18.3" to 39.3") Network/Communications Equipment Rack w/ Casters (4POSTRACK25) - rack - 25U
- Product Type
- Rack
- Flat black
- Height (Rack Units)
- 25U
- 57.1 cm x 100 cm x 122.5 cm
- 39 kg
- 3-year warranty
- Designed For
- P/N: CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM6, CABSCREWM62, CABSCREWS, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224
- Product Type
- Rack
- 25U
- 57.1 cm
- 100 cm
- 122.5 cm
- 39 kg
- Flat black
- Weight Limit
- 450 kg
- Limited warranty: - 3 years
- Designed For
StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet | In Stock | £20.33 |
StarTech.com 36U Adjustable 4 Post Server Equipment Open Frame Rack Cabinet | In Stock | £290.13 |
StarTech.com 12U 19in Desktop Open Frame 2 Post Rack | In Stock | £46.51 |
StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep | In Stock | £81.85 |
StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet | In Stock | £48.93 |
StarTech.com 3U 9in Deep Rackmount Locking Storage Drawer | In Stock | £57.26 |
StarTech.com Caster Kit for Open Frame Rack - 4POSTRACK | In Stock | £45.08 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £14.33 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £35.79 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £36.01 |
StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) | In Stock | £351.56 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £16.98 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £34.25 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £64.99 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £68.65 |
StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg | In Stock | £29.09 |
StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf | In Stock | £102.73 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £332.55 |
StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg | In Stock | £96.55 |
StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £71.80 |
StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £86.64 |
StarTech.com 12U 36in Knock-Down Server Rack Cabinet with Casters | In Stock | £390.45 |
StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel | In Stock | £37.34 |
StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg | In Stock | £57.33 |
StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg | In Stock | £46.30 |
StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg | In Stock | £41.35 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x5.9in (5.7x15cm) | In Stock | £5.34 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) | In Stock | £4.35 |
StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) | In Stock | £7.09 |
StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel | In Stock | £40.75 |
StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg | In Stock | £180.31 |
StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel | In Stock | £48.48 |
StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £26.99 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £68.65 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £36.59 |
StarTech.com Portable Server Rack - 9U | In Stock | £273.57 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £29.64 |
StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £23.71 |
StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £64.99 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £33.50 |
StarTech.com 50 Pkg M5 Mounting Screws | In Stock | £19.13 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £36.39 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £20.19 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £26.85 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £31.46 |
StarTech.com 19in Cable Management Panel | In Stock | £25.85 |
StarTech.com 18U Server Rack Enclosure | In Stock | £471.93 |
StarTech.com 6U Wall-Mount Rack Cabinet | In Stock | £155.92 |
StarTech.com 9U Wall-Mount Rack Cabinet | In Stock | £182.65 |
StarTech.com 9U Wall-Mount Rack Cabinet | In Stock | £203.01 |
StarTech.com 12U Server Rack Enclosure | In Stock | £403.70 |
StarTech.com 12U Server Rack Enclosure | In Stock | £289.22 |
StarTech.com 15U Server Rack Enclosure | In Stock | £359.30 |
StarTech.com 4U Open Frame Desktop Rack - 2-Post - Weight Cap. 66 lbs | In Stock | £34.12 |
StarTech.com M6 Mounting Screws 50Pack | In Stock | £20.19 |
